Stealth ram limit
rice B-4
PostPosted: Wed Feb 01, 2006 7:49 pm    Post subject: Stealth ram limit Reply with quote
How much power can a steath ram handle e.i. a twin turbo set up?
"Horse power is how fast you hit the wall, Torque is how far you take the wall with you."
99 Camaro Z28 LS1
PostPosted: Wed Feb 01, 2006 8:07 pm    Post subject: Reply with quote
with twin turbo's. Enough that I know, you would kill yourself before the peddle found the floor. Wink
PostPosted: Wed Feb 01, 2006 8:32 pm    Post subject: Reply with quote
I'm going to agree with john on this one and say when it comes to forced induction it's more a matter of how big your snails are. Smile
rice B-4
PostPosted: Wed Feb 01, 2006 9:08 pm    Post subject: Reply with quote
Dose that mean that you don't know? Confused
99 Camaro Z28 LS1
Sellmanb
PostPosted: Wed Feb 01, 2006 9:14 pm    Post subject: Reply with quote
I think they're trying to say that with forced induction, the last thing you would have to worry about is the intake Smile
PostPosted: Wed Feb 01, 2006 9:51 pm    Post subject: Reply with quote
I'm going to agree with Bobby.
Twin Turbos require a car AND $$
PostPosted: Wed Feb 01, 2006 10:04 pm    Post subject: Reply with quote
I'm going to rephrase this properly.
TIME and $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$.
PostPosted: Wed Feb 01, 2006 10:08 pm    Post subject: Reply with quote
936.4 HP (flywheel of course)
rice B-4
PostPosted: Thu Feb 02, 2006 5:35 pm    Post subject: Reply with quote
OK, if one were going to run twin turbos on a small block what type of fuel dilevery system would you guys recomend.
99 Camaro Z28 LS1
PostPosted: Thu Feb 02, 2006 5:38 pm    Post subject: Reply with quote
your questions are way to vague. it depends on the cam, the boost level, the motor, the ammount of money you plan to spend, if it is a race car, if emmsions are an issue or not, etc, etc, etc.
If you just wanted to get a discusion about forced induction, then great, but dude, ask more specific questions if you are trying to get information.
IMHO, I would run aftermarket FI, although a blowthru carb would be a fun project in its own right.
PostPosted: Thu Feb 02, 2006 6:38 pm    Post subject: Reply with quote
Thank YOU!!!!!
rice B-4
PostPosted: Thu Feb 02, 2006 7:46 pm    Post subject: Reply with quote
Running ten to twelve punds of boost on a 406 with a cam around 255/262 .575 114 lsa. max opperating range 7200 rpms. Non-emmissions to run on both street and strip.
99 Camaro Z28 LS1
PostPosted: Thu Feb 02, 2006 8:01 pm    Post subject: Reply with quote
None of us have that much money, we dont' exactly have much experiance with that much.
Really, if you where going to build a setup like that, you would probably be running aftermarket computer stuff, something like DFI. YOu would idealy want a computer that can do fuel trim per cyl, so some sort of SFI support would be wanted.
PostPosted: Thu Feb 02, 2006 9:05 pm    Post subject: Reply with quote
hehe well at least the lad answered the question about budget.
is this something you are building or are you bench racing someone or what? ohhh i bet you got to hang around with all these sexy thirdgens last weekend and now you have to have one. can't blame you for that Razz
PostPosted: Thu Feb 02, 2006 9:40 pm    Post subject: Reply with quote
wait... who is riceb4? was he at dyno with us or somthing?
PostPosted: Thu Feb 02, 2006 10:08 pm    Post subject: Reply with quote
That is Justin.
PostPosted: Thu Feb 02, 2006 10:39 pm    Post subject: Reply with quote
The only dude in the crew with an ls1.
So far.
About the fuel supply, look at any fourthgen board and i'm sure you'll find better answers than any thirdgen board. Tons of those guys need to supply their engines with a lot more power than we do. Not that my 247 ft/lbs is anything to scoff at.... Very Happy The supply setups will probably be very similar to what you'd need to run. Racetronix has a few interesting setups I think including a dual intank pump setup meant for up to ~1000hp.
