turbo_jimi Member
Posted: Wed Oct 19, 2005 9:22 pm Post subject: Emmisions question |
Hi,
I would like to know what size of bolts I need to use to plug up the holes left when I remove the aluminum tubing from the exhaust (manifold?) I currently have them capped off but they are taking up space and are completely useless. All 8 connection points look to be the same size. The help is appreciated.
TJ _________________
Posted: Wed Oct 19, 2005 9:29 pm Post subject: |
Take em off and cruise to the hardware store with em !  |
turbo_jimi Member
Posted: Wed Oct 19, 2005 9:43 pm Post subject: |
LOL...that's the plan...just thought if anybody knew right off hand, i could buy the supplies first and do the work later. Also, should I use the red or blue loc-tite when I install the bolts or anything at all? _________________
Posted: Wed Oct 19, 2005 10:47 pm Post subject: |
| I wouldn't worry about it. If you're that concerned you can spend $3 on exhaust sealer. Putty type stuff. little dab would seal the cracks. Cheaper and goes farther than loctite for exhaust applications. |
turbo_jimi Member
Posted: Wed Oct 19, 2005 10:56 pm Post subject: |
Cool, Thanks. _________________
