Emmisions question
PostPosted: Wed Oct 19, 2005 9:22 pm    Post subject: Emmisions question Reply with quote
Hi,
I would like to know what size of bolts I need to use to plug up the holes left when I remove the aluminum tubing from the exhaust (manifold?) I currently have them capped off but they are taking up space and are completely useless. All 8 connection points look to be the same size. The help is appreciated.
TJ
PostPosted: Wed Oct 19, 2005 9:29 pm    Post subject: Reply with quote
Take em off and cruise to the hardware store with em ! Wink
PostPosted: Wed Oct 19, 2005 9:43 pm    Post subject: Reply with quote
LOL...that's the plan...just thought if anybody knew right off hand, i could buy the supplies first and do the work later. Also, should I use the red or blue loc-tite when I install the bolts or anything at all?
PostPosted: Wed Oct 19, 2005 10:47 pm    Post subject: Reply with quote
I wouldn't worry about it. If you're that concerned you can spend $3 on exhaust sealer. Putty type stuff. little dab would seal the cracks. Cheaper and goes farther than loctite for exhaust applications.
PostPosted: Wed Oct 19, 2005 10:56 pm    Post subject: Reply with quote
Cool, Thanks.
