Posted: Sun Jul 01, 2012 1:52 pm Post subject: |
| I am wondering if water in fluid. |
Posted: Sun Jul 01, 2012 1:53 pm Post subject: |
| Then you need to find a couple big friends and go gently renege on the deal. |
Posted: Sun Jul 01, 2012 2:02 pm Post subject: |
| Great. So it is a wc , but for veesix |
Posted: Sun Jul 01, 2012 2:06 pm Post subject: |
| Don't know if it's WC. Take the bell off and get a pic of the front cover. |
Posted: Sun Jul 01, 2012 2:07 pm Post subject: |
| Anyways that fing sucks. My wife going to woop my butt. Oh well. That's what I get for being an idiot |
Posted: Sun Jul 01, 2012 2:08 pm Post subject: |
Posted: Sun Jul 01, 2012 2:16 pm Post subject: |
| Is input shaft on shifter side. I was reading and it says that v6 was 16 spline Amd v8 was 26? |
Posted: Sun Jul 01, 2012 2:20 pm Post subject: |
V6 is 14 spline, V8 is 26. You can clearly see that that transmission has a 14-spline input shaft in the pictures.
When I say "input" and "output" shafts you need to think about how a transmission works. |
Posted: Sun Jul 01, 2012 4:17 pm Post subject: |
It's not a wc. No wc had a dex ii tag. Its a v6 model. You got hustled. V6 t5s are free. A Ford or fourth gen will not work with a sbc period. _________________ A redline a day keeps the carbon away! |
Posted: Sun Jul 01, 2012 4:22 pm Post subject: |
Furthermore that input shaft has a very long pilot bearing surface not indicative of a gm. It looks like a 2wd 2.8l jeep truck trans. _________________ A redline a day keeps the carbon away! |
Posted: Sun Jul 01, 2012 4:30 pm Post subject: |
| Hustled and lied to. Sucks |
Posted: Sun Jul 01, 2012 4:46 pm Post subject: |
| Twilightoptics wrote: | | Furthermore that input shaft has a very long pilot bearing surface not indicative of a gm. It looks like a 2wd 2.8l jeep truck trans. |
Has the GM tailshaft on it, though. |
Posted: Sun Jul 01, 2012 5:00 pm Post subject: |
Tails are native to the mainshaft. Easy to swap for like era.
I used to convert v8 t5s into s10 shorter locations a lot. _________________ A redline a day keeps the carbon away! |
Posted: Sun Jul 01, 2012 5:06 pm Post subject: |
| Ahh, I was thinking that would require you to swap out the mainshaft. |
Posted: Sun Jul 01, 2012 5:32 pm Post subject: |
| Now dude is trying to postpone inevitableof swapping me back. I may have to tell him to kick down the chin spoiler he has lying around for my time and gas |
Posted: Sun Jul 01, 2012 7:50 pm Post subject: |
| aaron_sK wrote: | | Ahh, I was thinking that would require you to swap out the mainshaft. |
You do, but its easy. _________________ A redline a day keeps the carbon away! |
Posted: Mon Jul 02, 2012 8:48 pm Post subject: |
| Well I think he is going to swap me back for my cash tomorrow. I have to send my wife though because he won't do it if I am around. I have learned slot about t5s over the last two days though |
BluFbdy Member
Posted: Fri Jul 06, 2012 9:59 pm Post subject: |
Not that it helps but I skimmed over this thread and a thing to note about world class units is they have a recessed front bearing, the non world class does not, if its an original world class it will say timken on it _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri Jul 06, 2012 10:35 pm Post subject: |
| I ended up getting cash back from him |
Posted: Sat Jul 07, 2012 9:56 am Post subject: |
| BluFbdy wrote: | | Not that it helps but I skimmed over this thread and a thing to note about world class units is they have a recessed front bearing, the non world class does not, if its an original world class it will say timken on it |
WC transmissions on the front of the trans have a flat (tapered) style countershaft bearing. The NWC transmissions have a cupped barrel style bearing. _________________ A redline a day keeps the carbon away! |
