going to look at t 5
Goto page Previous  1, 2
jchaussee
PostPosted: Sun Jul 01, 2012 1:52 pm    Post subject: Reply with quote
I am wondering if water in fluid.
PostPosted: Sun Jul 01, 2012 1:53 pm    Post subject: Reply with quote
Then you need to find a couple big friends and go gently renege on the deal.
jchaussee
PostPosted: Sun Jul 01, 2012 2:02 pm    Post subject: Reply with quote
Great. So it is a wc , but for veesix
PostPosted: Sun Jul 01, 2012 2:06 pm    Post subject: Reply with quote
Don't know if it's WC. Take the bell off and get a pic of the front cover.
jchaussee
PostPosted: Sun Jul 01, 2012 2:07 pm    Post subject: Reply with quote
Anyways that fing sucks. My wife going to woop my butt. Oh well. That's what I get for being an idiot
jchaussee
PostPosted: Sun Jul 01, 2012 2:08 pm    Post subject: Reply with quote
jchaussee
PostPosted: Sun Jul 01, 2012 2:16 pm    Post subject: Reply with quote
Is input shaft on shifter side. I was reading and it says that v6 was 16 spline Amd v8 was 26?
PostPosted: Sun Jul 01, 2012 2:20 pm    Post subject: Reply with quote
V6 is 14 spline, V8 is 26. You can clearly see that that transmission has a 14-spline input shaft in the pictures.
When I say "input" and "output" shafts you need to think about how a transmission works.
PostPosted: Sun Jul 01, 2012 4:17 pm    Post subject: Reply with quote
It's not a wc. No wc had a dex ii tag. Its a v6 model. You got hustled. V6 t5s are free. A Ford or fourth gen will not work with a sbc period.
PostPosted: Sun Jul 01, 2012 4:22 pm    Post subject: Reply with quote
Furthermore that input shaft has a very long pilot bearing surface not indicative of a gm. It looks like a 2wd 2.8l jeep truck trans.
jchaussee
PostPosted: Sun Jul 01, 2012 4:30 pm    Post subject: Reply with quote
Hustled and lied to. Sucks
PostPosted: Sun Jul 01, 2012 4:46 pm    Post subject: Reply with quote
Has the GM tailshaft on it, though.
PostPosted: Sun Jul 01, 2012 5:00 pm    Post subject: Reply with quote
Tails are native to the mainshaft. Easy to swap for like era.
I used to convert v8 t5s into s10 shorter locations a lot.
PostPosted: Sun Jul 01, 2012 5:06 pm    Post subject: Reply with quote
Ahh, I was thinking that would require you to swap out the mainshaft.
jchaussee
PostPosted: Sun Jul 01, 2012 5:32 pm    Post subject: Reply with quote
Now dude is trying to postpone inevitableof swapping me back. I may have to tell him to kick down the chin spoiler he has lying around for my time and gas
PostPosted: Sun Jul 01, 2012 7:50 pm    Post subject: Reply with quote
You do, but its easy.
jchaussee
PostPosted: Mon Jul 02, 2012 8:48 pm    Post subject: Reply with quote
Well I think he is going to swap me back for my cash tomorrow. I have to send my wife though because he won't do it if I am around. I have learned slot about t5s over the last two days though
BluFbdy
PostPosted: Fri Jul 06, 2012 9:59 pm    Post subject: Reply with quote
Not that it helps but I skimmed over this thread and a thing to note about world class units is they have a recessed front bearing, the non world class does not, if its an original world class it will say timken on it
jchaussee
PostPosted: Fri Jul 06, 2012 10:35 pm    Post subject: Reply with quote
I ended up getting cash back from him
PostPosted: Sat Jul 07, 2012 9:56 am    Post subject: Reply with quote
WC transmissions on the front of the trans have a flat (tapered) style countershaft bearing. The NWC transmissions have a cupped barrel style bearing.
Page 2 of 2
