Posted: Wed Dec 21, 2011 6:12 pm Post subject: |
| Thats the way Ive always done chains |
Posted: Wed Dec 21, 2011 6:19 pm Post subject: |
If the marks are together, is that 1tdc, or 4tdc?
Ive always adjusted the 1st step of my valves with the dizzy pointing to 1..... which would be "up,up,1".
:edit: Ok, so up,up,1 is TDC. So I adjusted my valves correctly. I'm crossing my fingers the rattle was just lack of oil for a few seconds. |
Posted: Wed Dec 21, 2011 7:25 pm Post subject: |
You shouldnt be adjusting valves using that pattern where you adjust a certain number of them at tdc etc.. With a performance camshaft some valves may not be on the base circle.
It's much more safe to use the ICEO(EOIC) method. When the intake is closing adjust the exhaust valve, when the exhaust is opening adjust the intake valve. |
Posted: Thu Dec 22, 2011 3:32 am Post subject: |
| Its not a performance cam, its just a stock LT1 cam. |
Posted: Thu Dec 22, 2011 7:24 am Post subject: |
| Stand by my statement anyway. |
Posted: Thu Dec 22, 2011 8:37 am Post subject: |
Then you've been doing chains wrong. Sorry bud.
When the balancer mark is on the timing pointer you are tdc of #1.
Cam timing determines if that's the power stroke or exhaust artless.
Sprocket marks together for installation is tdc exhaust stroke. Aagain spin the motor over once after you put the timing cover on until the balancer and timing pointer line up. That's tdc #1 power stroke. Install distributor with the rotor.facing #1 plug wire
Adjust valves.like Brandon.said. _________________ A redline a day keeps the carbon away! |
Posted: Sat Dec 24, 2011 4:51 pm Post subject: |
Well, It ran..........
But I figured out what the noise was the first time. Seems that these vette valve covers have(had) these black tabs hanging down that the only point I see is to direct any oil spash to drip down to the pivot point. They dont get along with full body roller rockers. |
Posted: Sat Dec 24, 2011 7:52 pm Post subject: |
Oil drippers ! Common big block thing. _________________ A redline a day keeps the carbon away! |
Posted: Mon Dec 26, 2011 1:57 pm Post subject: |
| Finally runs. *sigh*. |
Posted: Tue Dec 27, 2011 8:39 am Post subject: |
| Twilightoptics wrote: | | Oil drippers ! Common big block thing. |
He has a small block. I dont think Ive seen oil drippers on my big block but i have the stock low rise truck covers.
Jay, all better now? _________________ E30
Posted: Tue Dec 27, 2011 10:19 am Post subject: |
I only ran it for a minuite or so. Going to check fluids tonight and try and pull out the garage. Will be a week or more I bet before I can go drive it due to weather. |
Posted: Tue Dec 27, 2011 4:03 pm Post subject: |
I know he has sbc. Pictures are obvious. Just saying drippers were a common BBC thing. _________________ A redline a day keeps the carbon away! |
Posted: Wed Dec 28, 2011 9:26 am Post subject: |
| blue89 wrote: | | I thought it was up, up, down, down, left, right, left, right? |
No, that's the God Mode cheat for Super Mario!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Dec 28, 2011 11:00 am Post subject: |
| RSFreak wrote: | | blue89 wrote: | | I thought it was up, up, down, down, left, right, left, right? |
No, that's the God Mode cheat for Super Mario!  |
Contra, but at least someone was amused by it! _________________ E30
Posted: Wed Dec 28, 2011 11:12 am Post subject: |
It's the KONOMI code!
Worked on lots of games.
Up Up Down Down Left Right Left Right B A B A (or a b a b lol) _________________ A redline a day keeps the carbon away! |
