Let the fun begin..............
Goto page Previous  1, 2
PostPosted: Wed Dec 21, 2011 6:12 pm    Post subject: Reply with quote
Thats the way Ive always done chains
PostPosted: Wed Dec 21, 2011 6:19 pm    Post subject: Reply with quote
If the marks are together, is that 1tdc, or 4tdc?
Ive always adjusted the 1st step of my valves with the dizzy pointing to 1..... which would be "up,up,1".
:edit: Ok, so up,up,1 is TDC. So I adjusted my valves correctly. I'm crossing my fingers the rattle was just lack of oil for a few seconds.
PostPosted: Wed Dec 21, 2011 7:15 pm    Post subject: Reply with quote
I thought it was up, up, down, down, left, right, left, right?
PostPosted: Wed Dec 21, 2011 7:25 pm    Post subject: Reply with quote
You shouldnt be adjusting valves using that pattern where you adjust a certain number of them at tdc etc.. With a performance camshaft some valves may not be on the base circle.
It's much more safe to use the ICEO(EOIC) method. When the intake is closing adjust the exhaust valve, when the exhaust is opening adjust the intake valve.
PostPosted: Thu Dec 22, 2011 3:32 am    Post subject: Reply with quote
Its not a performance cam, its just a stock LT1 cam.
PostPosted: Thu Dec 22, 2011 7:24 am    Post subject: Reply with quote
Stand by my statement anyway.
PostPosted: Thu Dec 22, 2011 8:37 am    Post subject: Reply with quote
Then you've been doing chains wrong. Sorry bud.
When the balancer mark is on the timing pointer you are tdc of #1.
Cam timing determines if that's the power stroke or exhaust artless.
Sprocket marks together for installation is tdc exhaust stroke. Aagain spin the motor over once after you put the timing cover on until the balancer and timing pointer line up. That's tdc #1 power stroke. Install distributor with the rotor.facing #1 plug wire
Adjust valves.like Brandon.said.
PostPosted: Sat Dec 24, 2011 4:51 pm    Post subject: Reply with quote
Well, It ran..........
But I figured out what the noise was the first time. Seems that these vette valve covers have(had) these black tabs hanging down that the only point I see is to direct any oil spash to drip down to the pivot point. They dont get along with full body roller rockers.
PostPosted: Sat Dec 24, 2011 7:52 pm    Post subject: Reply with quote
Oil drippers ! Common big block thing.
PostPosted: Mon Dec 26, 2011 1:57 pm    Post subject: Reply with quote
Finally runs. *sigh*.
PostPosted: Tue Dec 27, 2011 8:39 am    Post subject: Reply with quote
He has a small block. I dont think Ive seen oil drippers on my big block but i have the stock low rise truck covers.
Jay, all better now?
PostPosted: Tue Dec 27, 2011 10:19 am    Post subject: Reply with quote
I only ran it for a minuite or so. Going to check fluids tonight and try and pull out the garage. Laughing Will be a week or more I bet before I can go drive it due to weather.
PostPosted: Tue Dec 27, 2011 4:03 pm    Post subject: Reply with quote
I know he has sbc. Pictures are obvious. Just saying drippers were a common BBC thing.
PostPosted: Wed Dec 28, 2011 9:26 am    Post subject: Reply with quote
No, that's the God Mode cheat for Super Mario! Very Happy
PostPosted: Wed Dec 28, 2011 11:00 am    Post subject: Reply with quote
Contra, but at least someone was amused by it!
PostPosted: Wed Dec 28, 2011 11:12 am    Post subject: Reply with quote
It's the KONOMI code!
Worked on lots of games.
Up Up Down Down Left Right Left Right B A B A (or a b a b lol)
Page 2 of 2
