Posted: Tue Nov 01, 2011 9:14 pm Post subject: |
haha I am sure nothing was meant by it but didn't look good.
I am feeling the need for some true MRA action. When are you having a gathering?
Posted: Tue Nov 01, 2011 9:17 pm Post subject: |
Isn't it getting time for a holiday-ish gathering?  |
Posted: Tue Nov 01, 2011 9:32 pm Post subject: |
Yes, in fact it is!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Tue Nov 01, 2011 9:34 pm Post subject: |
Somebody name some dates and I'll host another gathering.
Pacific Raceways is having TNT on their road course for el cheapo. $100 day of registration...
November 6th Sunday
November 12th Saturday
November 19th Saturday
December 3rd Saturday
December 10th Saturday
December 17th Saturday _________________
BluFbdy Member
Posted: Wed Nov 02, 2011 12:19 am Post subject: |
Did my sarcasm get me in trouble again? My bad lol ill keep it to a minimum _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Wed Nov 02, 2011 2:22 am Post subject: |
Think it was my psuedo racist comment....... _________________ A redline a day keeps the carbon away! |
Posted: Wed Nov 02, 2011 9:39 am Post subject: |
I will add this to your cost list: transmission and axle. The very first time you hook up, BOOM! I will make sure i video my first wot run when i put my track tires on. The big block should be about the same amount of torque your turbo small block will put out. Hehe. _________________ E30
Posted: Wed Nov 02, 2011 9:42 am Post subject: |
| Ya, I knew tranny and rear end where toast. Thats why I have decided to build for a high hp motor and then if I go turbo, all then I have to do is spend money on turbo specific parts |
Posted: Wed Nov 02, 2011 11:08 am Post subject: |
| blue89 wrote: | | I will add this to your cost list: transmission and axle. The very first time you hook up, BOOM! |
Good call!
Posted: Wed Nov 02, 2011 11:11 am Post subject: |
| jchaussee wrote: | | Ya, I knew tranny and rear end where toast. Thats why I have decided to build for a high hp motor and then if I go turbo, all then I have to do is spend money on turbo specific parts |
And remember that a motor built for a Turbo is going to run like a 70's emissions pig without a turbo. _________________ A redline a day keeps the carbon away! |
Posted: Wed Nov 02, 2011 11:50 am Post subject: |
| Quote: | | And remember that a motor built for a Turbo is going to run like a 70's emissions pig without a turbo. |
Ouch, low blow. [/quote] |
Posted: Wed Nov 02, 2011 2:28 pm Post subject: |
| blue89 wrote: | | Quote: | | And remember that a motor built for a Turbo is going to run like a 70's emissions pig without a turbo. |
Ouch, low blow. | [/quote]
Posted: Wed Nov 02, 2011 4:41 pm Post subject: |
What 7.9 compression doesnt work NA?  |
Posted: Wed Nov 02, 2011 9:08 pm Post subject: |
We will see how much i can squeeze out of an emissions pig.
At least turbo to na is just a cam swap away. Damn bump sticks. I will say this to the $1k project build, if all you run is 7-10 psi, you probably dont need an intercooler. And a blow through holley is easier than you think. Upside down manifolds, repurposed carb, all you really need are the turbos, valves, and fuel delivery. And a couple extra engines laying about. |
Posted: Wed Nov 02, 2011 9:13 pm Post subject: |
| What on a min would need to be done to internals to make hold up to lets say 10 lbs boost? |
Posted: Thu Nov 03, 2011 12:14 pm Post subject: |
| I don't know much about turbos, but I think someone told me to pack the inside of the pistons full of peanut butter. Creamy, not chunky. |
Posted: Thu Nov 03, 2011 1:46 pm Post subject: |
Mmm, creamy pb....
Id say just boost it and find out. It seems to be a general rule that most engines will handle a measly 7-10 psi without blowing the manifold welds. |
Posted: Thu Nov 03, 2011 2:06 pm Post subject: |
| blue89 wrote: | | blowing the manifold welds. |
Aaay! That's from the other thread!
Also, chunky peanut butter is the way to go. Real chunky peanut butter with oil, no Jif hydrogenated BS. |
Posted: Thu Nov 03, 2011 2:07 pm Post subject: |
| blue89 wrote: | Mmm, creamy pb....
Watch out for your floor board to fall off the car too! _________________ A redline a day keeps the carbon away! |
Posted: Thu Nov 03, 2011 5:19 pm Post subject: |
| Dont forget to shift about 20times before then end of the parking lot |
