Heater Control vaccum
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jan 21, 2011 12:10 am    Post subject: Reply with quote
Heater valve ditch is a good idea. However he still needs to tap vacuum to run the doors under his dash. Otherwise he'll have nothing other than defrost. Women tend not to appreciate things like that. Razz
Is that how nonAC cars run it? My vacuum lines came through the firewall right below the heater core tubes (ish).
Separate grommet? I could have sworn the one in my IROC and the one in my Z were in the harness itself.
91camaro_rs
PostPosted: Fri Jan 21, 2011 8:25 am    Post subject: Reply with quote
i can totally agree with you there, my "friend" loves the heater in my camaro mainly cause it gets up to temp in like 2 minutes
PostPosted: Fri Jan 21, 2011 8:48 am    Post subject: Reply with quote
I can't say for 100% for I'm 98% sure the heater/AC wiring and vacuum lines came through their own grommet/section of the firewall almost dead center. /gnats memory
nonsensekid20
PostPosted: Fri Jan 21, 2011 10:56 am    Post subject: Reply with quote
So can I run a straight vacuum line to the controller?
nonsensekid20
PostPosted: Fri Jan 21, 2011 11:09 am    Post subject: Reply with quote
[quote="aaron_sK"]Haha... a cut-n-run guy, eh? Laughing quote]
Lol. I went from TBI to carbed, so i had to have taken out 100 wires. That harness that came through the passenger side fender had a bunch of wires i didn't need. But I still have the harness. If theres a vacuum line, I'll find it. lol
PostPosted: Fri Jan 21, 2011 11:41 am    Post subject: Reply with quote
That's what I'm doing. Shrug Can't say I've noticed the doors changing around while I'm driving.
PostPosted: Fri Jan 21, 2011 11:45 am    Post subject: Reply with quote
All you need to do is plug the line from the heater valve. Two separate hard lines going into the interior compartment. One for the heater valve, and one is engine vacuum feed.
nonsensekid20
PostPosted: Fri Jan 21, 2011 11:54 am    Post subject: Reply with quote
This is the same for a carbed engine right? and do you have the vacuum line running from the engine to the purple line? That's input from what i've seen.
PostPosted: Fri Jan 21, 2011 5:10 pm    Post subject: Reply with quote
nonsensekid20
PostPosted: Sun Jan 23, 2011 3:02 pm    Post subject: Reply with quote
So those 2 lines (Purple and Grey) Do they both hook into a vacuum line?
nonsensekid20
PostPosted: Sun Jan 23, 2011 3:37 pm    Post subject: Reply with quote
What does the heater valve do?
PostPosted: Sun Jan 23, 2011 5:00 pm    Post subject: Reply with quote
The heater valve diverts coolant from the heater core when cool settings are selected.
nonsensekid20
PostPosted: Sun Jan 23, 2011 5:09 pm    Post subject: Reply with quote
Doubt I'll even be using the cool air. lol. "bypass" Laughing
PostPosted: Sun Jan 23, 2011 5:21 pm    Post subject: Reply with quote
That valve was designed to keep the interior cooler when the windows were up and the aircon or vent was on. Which is stupid... Unless you're over forty. Then it starts to make sense again. Razz
nonsensekid20
PostPosted: Sun Jan 23, 2011 5:24 pm    Post subject: Reply with quote
Yeah, windows up.. wth? hahah. I got T-Tops! I don't need no stinkin A/C!
PostPosted: Sun Jan 23, 2011 5:30 pm    Post subject: Reply with quote
You still need to find where that purple feed tube terminates, and get it check-valved vacuum from the reservoir.
nonsensekid20
PostPosted: Sun Jan 23, 2011 5:35 pm    Post subject: Reply with quote
I had it hooked up to the carb earlier. Just straight tube. What's hooking it up to the canister do?
PostPosted: Sun Jan 23, 2011 5:46 pm    Post subject: Reply with quote
Not the evap canister.
The vacuum reservoir.
Usually under the evap canister. It keeps vacuum in the system when there is no vacuum. Since all the controls are vacuum operated, if you have your setting on vent.... and got WOT where there is no engine vacuum, the vent setting will end up on defrost. The reservoir keeps vacuum to the system so it doesn't change. Same with Cruise Control. Go up a hill where the engine has less vacuum, cruise might cut out without the reservoir. That's why the res is directly plumbed into the cruise and hvac system.
nonsensekid20
PostPosted: Sun Jan 23, 2011 5:49 pm    Post subject: Reply with quote
So how do you hook up the resivor?
PostPosted: Sun Jan 23, 2011 5:54 pm    Post subject: Reply with quote
Bashy Bashy
Dude, I don't mean to be rude here, but several people just wrote two pages here for you on how to do this. You could read it.
Page 2 of 4
