Posted: Fri Jan 21, 2011 12:10 am Post subject: |
Heater valve ditch is a good idea. However he still needs to tap vacuum to run the doors under his dash. Otherwise he'll have nothing other than defrost. Women tend not to appreciate things like that.
| iansane wrote: | | Is that how nonAC cars run it? My vacuum lines came through the firewall right below the heater core tubes (ish). |
Separate grommet? I could have sworn the one in my IROC and the one in my Z were in the harness itself. |
91camaro_rs Member
Posted: Fri Jan 21, 2011 8:25 am Post subject: |
| aaron_sK wrote: | Women tend not to appreciate things like that.
i can totally agree with you there, my "friend" loves the heater in my camaro mainly cause it gets up to temp in like 2 minutes _________________
Posted: Fri Jan 21, 2011 8:48 am Post subject: |
| aaron_sK wrote: | | Separate grommet? I could have sworn the one in my IROC and the one in my Z were in the harness itself. |
I can't say for 100% for I'm 98% sure the heater/AC wiring and vacuum lines came through their own grommet/section of the firewall almost dead center. /gnats memory |
nonsensekid20 Member
Posted: Fri Jan 21, 2011 10:56 am Post subject: |
| So can I run a straight vacuum line to the controller? |
Posted: Fri Jan 21, 2011 11:09 am Post subject: |
[quote="aaron_sK"]Haha... a cut-n-run guy, eh? quote]
Lol. I went from TBI to carbed, so i had to have taken out 100 wires. That harness that came through the passenger side fender had a bunch of wires i didn't need. But I still have the harness. If theres a vacuum line, I'll find it. lol |
Posted: Fri Jan 21, 2011 11:41 am Post subject: |
| nonsensekid20 wrote: | | So can I run a straight vacuum line to the controller? |
That's what I'm doing. Can't say I've noticed the doors changing around while I'm driving. |
Posted: Fri Jan 21, 2011 11:45 am Post subject: |
All you need to do is plug the line from the heater valve. Two separate hard lines going into the interior compartment. One for the heater valve, and one is engine vacuum feed. _________________ A redline a day keeps the carbon away! |
Posted: Fri Jan 21, 2011 11:54 am Post subject: |
| This is the same for a carbed engine right? and do you have the vacuum line running from the engine to the purple line? That's input from what i've seen. |
BigDaddyVu 12sec Club
Posted: Fri Jan 21, 2011 5:10 pm Post subject: |
Posted: Sun Jan 23, 2011 3:02 pm Post subject: |
| So those 2 lines (Purple and Grey) Do they both hook into a vacuum line? |
Posted: Sun Jan 23, 2011 3:37 pm Post subject: |
| Twilightoptics wrote: | | All you need to do is plug the line from the heater valve. Two separate hard lines going into the interior compartment. One for the heater valve, and one is engine vacuum feed. |
What does the heater valve do? |
Posted: Sun Jan 23, 2011 5:00 pm Post subject: |
| The heater valve diverts coolant from the heater core when cool settings are selected. |
Posted: Sun Jan 23, 2011 5:09 pm Post subject: |
Doubt I'll even be using the cool air. lol. "bypass"  |
Posted: Sun Jan 23, 2011 5:21 pm Post subject: |
That valve was designed to keep the interior cooler when the windows were up and the aircon or vent was on. Which is stupid... Unless you're over forty. Then it starts to make sense again.  |
Posted: Sun Jan 23, 2011 5:24 pm Post subject: |
| Yeah, windows up.. wth? hahah. I got T-Tops! I don't need no stinkin A/C! |
Posted: Sun Jan 23, 2011 5:30 pm Post subject: |
| You still need to find where that purple feed tube terminates, and get it check-valved vacuum from the reservoir. |
Posted: Sun Jan 23, 2011 5:35 pm Post subject: |
| I had it hooked up to the carb earlier. Just straight tube. What's hooking it up to the canister do? |
Posted: Sun Jan 23, 2011 5:46 pm Post subject: |
Not the evap canister.
The vacuum reservoir.
Usually under the evap canister. It keeps vacuum in the system when there is no vacuum. Since all the controls are vacuum operated, if you have your setting on vent.... and got WOT where there is no engine vacuum, the vent setting will end up on defrost. The reservoir keeps vacuum to the system so it doesn't change. Same with Cruise Control. Go up a hill where the engine has less vacuum, cruise might cut out without the reservoir. That's why the res is directly plumbed into the cruise and hvac system. _________________ A redline a day keeps the carbon away! |
Posted: Sun Jan 23, 2011 5:49 pm Post subject: |
| So how do you hook up the resivor? |
Posted: Sun Jan 23, 2011 5:54 pm Post subject: |
Dude, I don't mean to be rude here, but several people just wrote two pages here for you on how to do this. You could read it. |
