Whats the best setup for exhaust for my 5.7 TPI
Goto page Previous  1, 2
PostPosted: Wed May 03, 2006 9:48 am    Post subject: Reply with quote
Being that you get disconunts, look at SLP, Hooker, or Hedman. They are all abotu the same. Go with whichever you get the best deal on.
PostPosted: Wed May 03, 2006 9:55 am    Post subject: Reply with quote
i would pick hooker just for the name Very Happy
PostPosted: Wed May 03, 2006 9:57 am    Post subject: Reply with quote
But why would we listen to your advise Tony. You have admited to "Tony-rigging" your car, with JB-Weld.
PostPosted: Wed May 03, 2006 10:02 am    Post subject: Reply with quote
only interior pieces... besides is'nt this coming from the guy with a bottle cap holding up his clutch reservoir or somthing? and the guy who we had to pull over for so he hould plug a wire back in that falls of somtimes?
i only "tony-rig" on the side of the road.... and my "tony-rigs" are freaaking automotive art. chris can vouch, the brush is to piccasso what diagonal cutters and electrical tape are to tony. Very Happy
PostPosted: Wed May 03, 2006 10:05 am    Post subject: Reply with quote
That bottle cap is just holding my nitrous purge noid up. and it was actualy Paul who did it. I just haven't changed it. Very Happy
PostPosted: Wed May 03, 2006 10:08 am    Post subject: Reply with quote
actualy, that one is prety cool... besides it's not a jery-rig unless it is on somthing important.
PostPosted: Wed May 03, 2006 10:16 am    Post subject: Reply with quote
well, the bracket for the purge noid is kind of flimsy, so the bottle cap just holds it up, it is just sitting between the heater-box and the noid, to keep it from rattling and moving.
PostPosted: Wed May 03, 2006 12:29 pm    Post subject: Reply with quote
jakemk8706 wrote:
well portland sucks cause i have to go through deq and right now the car has no cats. it has a good sound but failed the test misserbly (looked good doin tho and went down like a champ). but i already ordered the high flows and will have them installed. my plan is to pass the emissions test, then buy exaust system stuff and possibly go no cats and see about some how fanagle my way into special plates thru DMV by saying its a rec. vehicle. but thats just what i have heard thru the grape vine and im not 100% sure if it will work.
If you're going to go that route, just by a crappy universal off-the-shelf cat and install it for the test. Clamp it, don't weld, and then you can replace it with a straight pipe afterwards.
Or you could do like good ol' Dewey did, and weld flanges to each end so you can remove it without using clamps. Laughing
PostPosted: Wed May 03, 2006 5:04 pm    Post subject: Reply with quote
thats my plan.
PostPosted: Wed May 03, 2006 5:22 pm    Post subject: Reply with quote
I've been thinking about either a system like that, or true duals, but it's too closed-ended. If I want to swap in a new engine, or a trubo setup, I'd have to rip out the exhaust to do it.
For now I'm going to leave what I've got on there, and get some money for another build-up.
PostPosted: Wed May 03, 2006 10:32 pm    Post subject: Reply with quote
I'm leaving the cat on my Car, even though I don't have to DEQ....
Just one more thing to clean up emissions.....besides, is not like its going to be that much of a restriction for my less-than-mighty 305.
Demon
PostPosted: Thu May 04, 2006 10:14 pm    Post subject: Reply with quote
exhaust wise, don't just get some painted headers, spend the extra cash and get coated headers, or at a minimal, stainless. having headers that look like shizzle after awhile kind of sucks, not to mention the whole heat thing.
the headers i bought are stainless and coated along with the y-pipe and I think for the heat reduction in the engine bay alone I'll be happy
for shorties, the Jet Hot Coated Hookers are usually best for a non-stainless header, but the SLP Stainless and Ceramic Coated are probably the best ones around, but most expensive at anywhere from 650-750 for a set with a y-pipe
medium or long tube headers, not as many options that work well, with the majority hanging too low, but PaceSetter makes a good set for the 3rdgen.
for cat-backs... Corsa and PaceSetter make nice sounding exhausts, though not as common as a flowmaster or a hooker aerochamber like a few members here have
its all a matter of cost and personal preference though, if you want non-coated headers its up to you of course, but ask those who have them and get their thoughts.
a header is a header when it comes down to it, but how long it lasts is up to you and your $$.
also, a good alternative to header bolts/studs are the Breslin split-lock locking header bolts... pretty nice, cost a little more but are well worth it
Soon to be less than stock
PostPosted: Fri May 05, 2006 12:35 am    Post subject: Reply with quote
i also like the idea of a torx header bolt (they do make em), this allows you to get a bit in there and actualy tighten them. i plan on getting some.
Page 2 of 2
