Posted: Sun Jul 31, 2011 7:41 pm Post subject: |
| 1987_sportcoupe wrote: | | what about just the sway bars? and do you have the end links for the rear sway bar as my car didn't come with a rear bar |
I have a rear bar with end links and bushings sitting in the garage. I think it's 21 or 22mm, just a tad smaller than the 23mm I'm keeping for my V6. I have the end link mounting brackets too, but not the bolts, you'd actually be better off to get new links and bushings. You'll also need the mounts for the bushings since you don't have a bar on your car. $20 and the bar is yours. _________________ 92 Camaro
kurfbird Member
Posted: Mon Aug 01, 2011 6:19 pm Post subject: bars |
60.00 for just the front and rear bars _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
IROCDave Member
Posted: Wed Aug 03, 2011 9:26 am Post subject: |
| Got any black sun visors in really good shape? I also need the clear liscence plate light fixtures that attach to the tailights. One left and one right, hopefully not crazed. |
Posted: Wed Aug 03, 2011 9:54 am Post subject: |
| IROCDave wrote: | | Got any black sun visors in really good shape? I also need the clear liscence plate light fixtures that attach to the tailights. One left and one right, hopefully not crazed. |
I have black sunvisors in perfect shape that I was going to use, but have decided not to. What were you hoping to pay?
They have the carburetor starting instructions on the label, if that matters to you this may not be what you are looking for.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed Aug 03, 2011 7:05 pm Post subject: |
| Alphius wrote: | | They have the carburetor starting instructions on the label |
Now a woman will never be able to figure out how to start his car.  |
Posted: Wed Aug 03, 2011 7:18 pm Post subject: |
| That's allright.. my carb car has the EFI starting instructions. Might take alot of cranking if you follow them and don't touch the accelerator pedal! |
jchaussee Member
Posted: Wed Aug 03, 2011 7:57 pm Post subject: |
| I need those carb instuctions apperantly. |
