messed up electrical
Goto page 1, 2, 3, 4  Next
jchaussee
PostPosted: Tue Jul 26, 2011 6:41 pm    Post subject: messed up electrical Reply with quote
So when I rev car volts are good, as soon as I put into drive they drop. Idles decent also unless I turn on radio, lights, blinkers, etc. Seems to bounce up and down to the beat of my radio, or to the flicker of my blinkers. I want to start with free checks before I start replacing stuff. I am an electrical idiot, but I follow directions well
PostPosted: Tue Jul 26, 2011 6:48 pm    Post subject: Reply with quote
Did you reconnect that wire you cut from the altenator? You mentioned you did that previously. Also sounds like a grounding problem.
PostPosted: Tue Jul 26, 2011 6:56 pm    Post subject: Reply with quote
Problem could be a weak battery, voltage regulator (in the alternator), or even bad grounds - check your battery terminals.
To check the regulator, measure the output post of the alternator (big wire on the back side) with a volt meter or digital multimeter set to DC volts. with the car motor running, you should see about 14 volts. It should stay relatively steady at 14 volts as the RPMs increase.
jchaussee
PostPosted: Tue Jul 26, 2011 7:25 pm    Post subject: Reply with quote
I haven't reconnected wire yet, but I did this previous to cutting it. And as far as big wire on alternator, would that be one coming fom my battery. I have several wires connected to my alternator on a bolt . Not a plug like on my truck
PostPosted: Tue Jul 26, 2011 7:44 pm    Post subject: Reply with quote
I don't think there should be several wires connected there. there are 2 wires connected to the back bolt, a wire going to the positive battery cable, and a wire going into a loom to the auxillary components like guages, electric choke, ect. You can follow this on the wiring diagram I posted in your other inquiry.
PostPosted: Tue Jul 26, 2011 8:05 pm    Post subject: Reply with quote
That's standard behavior for an old-style alternator with the reference wire disconnected. If you don't have a smallish two-wire plug plugged into your alt, then that would be why.
PostPosted: Tue Jul 26, 2011 8:17 pm    Post subject: Reply with quote
The one wire that GM put there goes down and connects to all the fusible links at the starter. Wink The thing he has to watch out for is that some moron redneck didn't run something straight off the back of the alternator with no fuse, 'cause that's car fire time when you start getting that stuff.
Bingo, Gabe. In his last topic he claimed to have cut those wires. I told them to trace them and connect them correctly. He ignored my good advice and the started a new topic. However my advice remains the same. Laughing
jchaussee
PostPosted: Tue Jul 26, 2011 8:45 pm    Post subject: Reply with quote
It still did same thing before I cut wire, I will put it back, but problem will remain. And it looks as if some redneck wires it because it has three wires connected to a bolt and none of them have fuses. The one I cut is spliced into some blue wire and the fan relay was also spliced into it before I cut it out. I will look at it more closely tommorow and see where all wires are going. I started new thread so I can fix the whole problem, because as stated before, nothing at all changed when I cut the wire.
PostPosted: Tue Jul 26, 2011 8:52 pm    Post subject: Reply with quote
Sounds like it was rednecks vs. logic under there, man. Laughing
Time to start tracing wires, kill what you don't need, and run things you do need correctly. Everything needs to have a fuse or a fusable link, and it needs to come from someplace where the sense wire can detect the draw.
jchaussee
PostPosted: Tue Jul 26, 2011 9:11 pm    Post subject: Reply with quote
Ya. I am going to start tommorow. I was also reading up on alternators and they mentioned an " exiter wire"???? I just want to get this damn thing running right
PostPosted: Tue Jul 26, 2011 9:17 pm    Post subject: Reply with quote
Yup.
Exciter wire / trigger wire / ect. Smallest wire. Brown or green usually. Turns the alternator regulator on and off. Connected to ignition switch.
Sense / reference / ect. Larger of the two small wires. Red or orange. Senses amount of voltage being put out by alt, and voltage draw. Adjusts regulator accordingly. Connected to the main lug on the starter solenoid, or other large connector where the alternator power and fusebox meet.
Output. Largest wire off of large lug. Feeds all electrical accessories on car, charges battery. Should be headed for the starter relay.
Ground: Some alternators have a ground strap if they're not grounded to the engine.
jchaussee
PostPosted: Wed Jul 27, 2011 2:47 pm    Post subject: Reply with quote
so it does have a plug. With two wires going into it. A small brown one that is spliced to the brown one that I cut when chopping out my ecm wires. That brown wire goes somewhere towards my driver side. Then the othr plug wire is a maybe 10 gauge or so red wire that loops to the bolt on my alternator. Then on bolt is another wire that connects to possitive side of battery. The battery itself is grounded out on the bolt that connects my alternator to the head.
PostPosted: Wed Jul 27, 2011 3:08 pm    Post subject: Reply with quote
I'm looking at my diagrams. Not knowing what year you have, I'm going by 90+ since your saying it has 3 wires.
The brown one goes to a fuse panel. It needs 20a.
The red one in the plug should go to some fusible links down by the starter.
The red lug on the back, should also go to some different fusible links, down by the starter.
Also check and make sure all your battery wires have never had corrosion. If they have, Ive seen ALOT lately that the wire was damaged down inside the sheathing due to previous corrosion.
jchaussee
PostPosted: Wed Jul 27, 2011 3:11 pm    Post subject: Reply with quote
Ya. It is obviosly messed up. I don't really need it to match a specific year, I just want it to function the way an alternator does. It is an 85, but has a swapped in 327. But nothing goes towars starter or any fusible links.
PostPosted: Wed Jul 27, 2011 3:12 pm    Post subject: Reply with quote
Doesn't that one normally have some sort of resistor or light bulb in the line? I kind of remember seeing some drawings like that.
PostPosted: Wed Jul 27, 2011 3:45 pm    Post subject: Reply with quote
When wired correctly, the stock gauge cluster has resistance built in that triggers the excite wire.
jchaussee
PostPosted: Wed Jul 27, 2011 4:21 pm    Post subject: Reply with quote
Can I then assume that the fat wire that comes out of the plug and loops itself to the lug on the back of the alternator is wrong. ??
PostPosted: Wed Jul 27, 2011 4:33 pm    Post subject: Reply with quote
Let's look at the 1985 diagram that is attached and start from the ignition switch.
Yellow wire goes from ignition switch to "clutch start" switch, then purple wire goes from "clutch start" switch to starter solenoid.
Now black wire runs from ignition switch through fusible link into starter (or solenoid...can't tell), then, to positive battery terminal then to altenator (on the back bolt.
Now there is the plug that goes into the altenator with red and black wiring...the red to power and black to ground.
The last wire is brown (or faded tan/rust color from age) that connects to the bolt on the altenator and goes to the automatic choke and the guages(including idiot lights).
It will not look like it's going in any one direction being that it's loomed.
The diagram is pretty explanatory except the brown wire goes off of the page near the lower left, but reappears about 2/3s the way up...it is the only brown wire.
PostPosted: Wed Jul 27, 2011 4:44 pm    Post subject: Reply with quote
This depends on what type of alternator you have. If it is the "older" 10si or 12si then you need a light, resistor or diode or you can potentially have a run-on issue. If he connects the wire as it was stock (which it sounds like it is) then he will be fine.
It's not "wrong" per-se since GM actually did wire some of them that way from the factory. It will however cause a dimming problem and is a poor design because the alternator never "sees" the voltage drop. Get a wire of the same color and gauge and run it to the fusable link lug on the starter.
So the alternator is feeding the battery and not the starter lug? That will cause issues because all the juice that the car draws while running has to come through the battery positive wire. Run the alternator output wire down to the starter lug. Make sure to use the same color and gauge. Also note that the alternator hot wire should have a fusable link in it.
Also, if the car will make a distance run, feel free to bring it out to my shop and I can help you with this. I'm off work this week.
jchaussee
PostPosted: Wed Jul 27, 2011 4:51 pm    Post subject: Reply with quote
the positive side of the battery has the wire that splits to the alternator and starter. And as far as fusible links go because I will be installing them myself , for there are none, do I get the kind that have spade fuses, or the twisty kind with the glass fuses, o does it matter, and what guage of wire??
Page 1 of 4
