Is this bad?
Goto page 1, 2, 3  Next
PostPosted: Sun Jun 19, 2011 5:54 pm    Post subject: Is this bad? Reply with quote
While adding an ebrake to my car ( Very Happy ) I saw this in the diff. Is this supposed to be jagged looking like this?
PostPosted: Sun Jun 19, 2011 7:47 pm    Post subject: Reply with quote
Hmm, I don't remember the diff cover needing to come off when I put my cables in. Squint
PostPosted: Sun Jun 19, 2011 7:52 pm    Post subject: Reply with quote
I swapped to LS1s from my LT1s. Shrug
PostPosted: Sun Jun 19, 2011 8:10 pm    Post subject: Reply with quote
I was thinking the same thing! Laughing
PostPosted: Sun Jun 19, 2011 8:26 pm    Post subject: Reply with quote
You have to pull the axles to change the backing plates for the LS1 brakes, not for the cables Razz
PostPosted: Sun Jun 19, 2011 8:53 pm    Post subject: Reply with quote
So I'm not sure if it's because I rotated the axles a ton while doing this or what, but now the upper and lower spider gears have slide out of alignment and I can't get the rod back in. I tried tapping on the gears to get them to pivot back into place and no dice. Do I have to pull the springs?
PostPosted: Sun Jun 19, 2011 9:06 pm    Post subject: Reply with quote
Car in gear, spin the wheels until the gear lines up. Careful.. dont spin the gears completely out.
Edit.. BY HAND!
PostPosted: Sun Jun 19, 2011 9:13 pm    Post subject: Reply with quote
The spiders are rotating along with the housing, unmoving in relation to the housing (and the hole I'm trying to line up is in the housing). Let me grab a picture.
Edit;
PostPosted: Sun Jun 19, 2011 9:15 pm    Post subject: Reply with quote
You have to move both tires.. same direction. I at first figured your posi would do that for you. I usually block one tire with my foot while i turn the other.
PostPosted: Sun Jun 19, 2011 9:16 pm    Post subject: Reply with quote
And of course you cant let the driveline turn either.. thus put it in gear.
PostPosted: Sun Jun 19, 2011 9:19 pm    Post subject: Reply with quote
Laughing Wow. So simple a caveman could do it. Thanks B.
PostPosted: Mon Jun 20, 2011 7:48 am    Post subject: Reply with quote
A tuke a zug zug.
IROCDave
PostPosted: Mon Jun 20, 2011 3:51 pm    Post subject: Reply with quote
Make sure you chock the front tires also, you know, so the car and the floor jack dont roll down the street Very Happy
PostPosted: Mon Jun 20, 2011 4:53 pm    Post subject: Reply with quote
That has probably happened to Ian! Laughing
PostPosted: Mon Jun 20, 2011 6:42 pm    Post subject: Reply with quote
Laughing
No but when the ball joint nut came off back in '04 I had to have a cop help me push it off the road with a floorjack holding up one corner. Laughing
PostPosted: Mon Jun 20, 2011 6:43 pm    Post subject: Reply with quote
So I found out today I'm missing a bracket on both sides that holds the end of the ebrake cable. So even after swapping to the LS1s I have no ebrake. Gaaaaahhh!
PostPosted: Mon Jun 20, 2011 7:13 pm    Post subject: Reply with quote
Missing the pieces that attach to the lower control arm mounts? Like this one?
PostPosted: Mon Jun 20, 2011 7:17 pm    Post subject: Reply with quote
Yes exactly! I probably took them off years ago when I welded on the reloc brackets and they've disappeared since then.
PostPosted: Mon Jun 20, 2011 7:26 pm    Post subject: Reply with quote
LT1 brackets are different than these IIRC.
These won't fit around the relocation brackets. There are three ways around that though. You can cut one of the mounting ears off and use only the one side (just break the weld and use the outside mounting ear). Break them apart at the weld, widen them and weld back together (alloy did this IIRC). Or do the first option and weld to the relocation brackets. Looks like maybe a trip to the JY to find a 98-02 F-body.
The fitment issue is the main reason I haven't installed relocation brackets yet.
PostPosted: Mon Jun 20, 2011 10:36 pm    Post subject: Reply with quote
I might have a set of those for that LS1 rear Ian. Let me look tomorrow.
Page 1 of 3
