Lots of good thirdgen parts -UPDATED 9/4/11 Pictures PG3
Goto page 1, 2, 3, 4  Next
PostPosted: Mon Jun 13, 2011 11:40 am    Post subject: Lots of good thirdgen parts -UPDATED 9/4/11 Pictures PG3 Reply with quote
4x6 Front Speakers. Pioneer TS-G4641R
-Perfect shape. Hardly used. Can't find the original bracket to use them in my Jeep, so they have to go.
-$15
IROC single Vein Wheels REAR pair polished and painted inserts black with MT Drag Radials with about 30 passes on them.
-$250
Glass T-Tops w/ keys
-$30 pair
Hayes Flywheel SFI
153 Tooth
2piece rear main
-$50
PM's are best for buys, offers, what else I have. I take paypal and credit cards through paypal. And of course cash. Pictures upon request. Removal comences this week.
-P
Last edited by Twilightoptics on Mon Jan 02, 2012 11:05 am; edited 24 times in total
PostPosted: Mon Jun 13, 2011 3:27 pm    Post subject: Reply with quote
Do you remember how many miles are on the rear Koni Yellows?
PostPosted: Mon Jun 13, 2011 7:05 pm    Post subject: Reply with quote
PM sent.
jchaussee
PostPosted: Mon Jun 13, 2011 7:37 pm    Post subject: Reply with quote
Ill take the ac delete box
PostPosted: Mon Jun 13, 2011 7:49 pm    Post subject: Reply with quote
Some reason this feels like sharks circling. Crying or Very sad
PostPosted: Mon Jun 13, 2011 8:37 pm    Post subject: Reply with quote
For the apillar pod, what do you mean when you say with trim?
PostPosted: Mon Jun 13, 2011 8:42 pm    Post subject: Reply with quote
It's the autometer full pillar. But it uses the original "trim" piece or "pillar" if you will.... to attach to. It's like a cover basically. That's what they mean by "full pillar gauge pod."
PostPosted: Tue Jun 14, 2011 4:15 am    Post subject: Reply with quote
Can you post me a pic of the headlight housings. Not sure if thats the style I'm looking for.
I'll take the Konis if Alphius doesnt.
PostPosted: Tue Jun 14, 2011 5:23 pm    Post subject: Reply with quote
I may be interested in the 6AL box. Gotta wait until next Thur, and I'll see how I'm sitting with $$.
PostPosted: Thu Jun 16, 2011 7:12 pm    Post subject: Re: Lots of good thirdgen parts Reply with quote
Corvette C4 HD 13" front brake setup: Modified spindles, Ed Miller caliper carrier brackets, Calipers, Hardware, Hawk HPS pads about 75%, Russell or Earls Stainless Steel Brake Lines, ARP racing lonig studs w/ acorn lug nuts. Rotors need turning or replacement. They have a slight warp and are a little thin.
-$400
I'll buy this. I'll take the brake proportioning valve, too, if you have it. My car was a rear drum brake car and I need to balance out the brake line pressure.
- Jon
PostPosted: Fri Jun 17, 2011 9:41 pm    Post subject: Reply with quote
So sad, but so many good parts. Need a straight low mile roller?
PostPosted: Fri Jun 17, 2011 11:02 pm    Post subject: Reply with quote
Not right away.
Still looking to go EFI? Very Happy
PostPosted: Fri Jun 17, 2011 11:05 pm    Post subject: Reply with quote
Yes I am.
PostPosted: Mon Jun 20, 2011 4:16 pm    Post subject: Reply with quote
will the 6AL work with a coil-n-cap HEI? if so, I think I'll take it. Do you have any extra RPM limit pills? if so what are they?
PostPosted: Mon Jun 20, 2011 4:47 pm    Post subject: Reply with quote
Think all I've got is the 7000rpm limit it has in it.
I would assume it works with a coil in cap, but I'm not sure. I'll have to look at the instructions.
PostPosted: Mon Jun 20, 2011 5:38 pm    Post subject: Reply with quote
It will work.. you just unplug the harness from the cap, and hook the msd between it. MSD has a harness to make it easy if you want too. If you do this make sure you buy a low resistance center cap electrode. The extra power will burn the carbon type electrode out and melt the cap.
PostPosted: Mon Jun 20, 2011 6:31 pm    Post subject: Reply with quote
so there's the 3 wire, the Batt and Tach plugs.. what and where do I need to splice? Also if Paul's got instructions, that'll be a huge help, it'll probably be pretty evident too.
I think I'll go for it. Paul, you have a PM.
PostPosted: Mon Jun 20, 2011 6:43 pm    Post subject: Reply with quote
Instructions are all available on msd's site as well. 2 ways to hook it up. 1: take the signal off the ignition module to the msd, then the trigger wires hook to the coil. Power wire is disconnected from the coil, but I think has to be hooked up to the module. OR the better way..
Unhook the original ignition module. Hook the pickup wires directly to the MSD and the coil wires from the msd to the incap coil. No power wire is needed at the distributor.
Their instructions will give you more detail. The 2nd way is how I have the pontiac hooked up.. except I got an external cap adapter and moved the coil out of cap.
PostPosted: Fri Jun 24, 2011 4:38 pm    Post subject: Reply with quote
Longshot, but do you have the condensor still Paul? I figure its long gone.. but possible.
PostPosted: Fri Jun 24, 2011 5:46 pm    Post subject: Reply with quote
A/c was gone like 10 years ago.
Page 1 of 4
