aluminum rear brake drums
badbob66
PostPosted: Fri Jun 03, 2011 2:46 pm    Post subject: aluminum rear brake drums Reply with quote
for sale is two set's of aluminum brake drums, 4 brake drums total.
They are in good shape, 2 drums need to be turned just to get the rust off the braking surface NOT because they are worn badly.
$30.00 for all 4 drums.
Located in Camas , WA.
Thanks
Bob
1986 trans am
1985 Honda fl350 Odyssey(No it's not a MINI VAN)
1985 honda 250R ATC
badbob66
PostPosted: Tue Jun 07, 2011 7:11 pm    Post subject: brake drums Reply with quote
brake drum pic Smile
1986 trans am
1985 honda 250R ATC
PostPosted: Tue Jun 07, 2011 7:23 pm    Post subject: Reply with quote
Can you hold on to the drums for a bit? Mine have been turned for the last time and I'm thinking of replacing them very soon. I'm having issues with the rears randomly locking before the fronts, I know it's the star wheel adjustment, but can't get it right for some reason.
PostPosted: Tue Jun 07, 2011 7:56 pm    Post subject: Reply with quote
Al, you most likely arent getting the brakes tight enough. It's counter-intuitive. Drum brakes are self actuating. The more movement they have, the more cam action there is to lock them into the drum. You want to tighten them up till the drum is locked.. then just back them off a few clicks.
PostPosted: Tue Jun 07, 2011 8:01 pm    Post subject: Reply with quote
Thanks Brandon. That does seem odd. So they're not tight enough for the self adjusters to work correctly? I still need new drums soon.
badbob66
PostPosted: Wed Jun 08, 2011 5:46 pm    Post subject: Reply with quote
When do you want to get them? I can hold them for awhile, I'M moving in July and need to get rid of all my extra parts.
Thanks
Bob
1986 trans am
1985 honda 250R ATC
PostPosted: Wed Jun 08, 2011 9:10 pm    Post subject: Reply with quote
By the end of the month, no later. I'll give you a heads up when I can come down. Thanks.
badbob66
PostPosted: Thu Jun 09, 2011 5:59 am    Post subject: Reply with quote
OK, sounds good I will hold them for you.
Thanks
Bob
1986 trans am
1985 honda 250R ATC
