d00012 Member
d00012 Member
Posted: Wed May 25, 2011 9:46 am Post subject: |
| Yes, they appear long enough. They have about an inch or more. |
Posted: Wed May 25, 2011 1:44 pm Post subject: |
Ouch, that's pretty bad...  _________________ 84 Camaro Z28 - LS1/T56
Posted: Wed May 25, 2011 5:02 pm Post subject: |
After finally seeing how this cracks. I'm trying to figure out how the wonder bar actually helps correct this?  _________________ 2008 GMC Z71
Posted: Wed May 25, 2011 5:06 pm Post subject: |
It's simple triangulation. The wonderbar ties both frame "horns" together making a U shape rather than two | | shapes. And it helps with deflection from turning. Instead of putting all the turning pressure on one horn out in the middle of nowhere, it dispurses it amongst both sides.
That's a NASTY break and will take a good day to repair properly. _________________ A redline a day keeps the carbon away! |
IROCDave Member
Posted: Wed May 25, 2011 5:35 pm Post subject: |
| I have a mig welder with argon gas in the garage that you can use. Im no welder though, might want to bring one with. |
