Holley FTW
Goto page Previous  1, 2
PostPosted: Mon May 23, 2011 7:09 pm    Post subject: Reply with quote
RK82 wrote:
only thing I don't like is the purple
Rattle can that sucker! Very Happy
Purple color has decal power...5 extra horses Wink
PostPosted: Mon May 23, 2011 7:28 pm    Post subject: Reply with quote
Is the engine stock or built up? I know on mine I fixxed most of my carb issues with the ignition timing.
RK82
1982 Pontiac Trans Am
PostPosted: Mon May 23, 2011 7:54 pm    Post subject: Reply with quote
its stock, the secondary were just opening way to early, I could get them half way open sitting in the driveway revving it, it dosen't bogg now but the idle is still kinda rich, I just have to adjust the A/F screws.
PostPosted: Mon May 23, 2011 7:57 pm    Post subject: Reply with quote
Yup yup
RK82
PostPosted: Tue May 24, 2011 6:02 pm    Post subject: Reply with quote
Yup yup
I wish.. all my issues don't respond at all to ignition timing
PostPosted: Tue May 24, 2011 8:02 pm    Post subject: Reply with quote
RK82 wrote:
Yup yup
Yeah, stock engine is way differant to tune driveability issues than an engine with a big cam. Stock is hard to beat the stock carb and ignition in proper working order.
RK82
PostPosted: Fri May 27, 2011 4:04 pm    Post subject: Reply with quote
wow, I never realized how big float height is on these carbs, both the primary's and secondary's where way to high, I set them so the primary's just barely dribble out the sight plug, and the secondary's so you have to give it a little shake to get fuel out the sight plug, it immediately started running better, adjusted the idle mix screws a little hopefully my issue is now fixed
this is my issue, I was leaving little black puddles everywhere I went
Page 2 of 2
