rscamaro89 New Member
Joined: 10 Jan 2004 Posts: 23 Location: Hillsboro, OR
Posted: Mon Jan 26, 2004 11:35 pm Post subject: Need info on what motor is in a '91 |
Well, I think I may have found the car that I am looking for. It is a 91 RS with about 100,000 miles on it. 305, 5spd T-tops... It's got the '92 ground effects on it and 16" wheels. Just wondering if the engine in the car is supposed to be TPI or TBI or Carbourated??? What ever is in it looks brand new, there is like no oil/grime/dirt at all in the engine compartment. Let me know so I can put more thought into before I decide on buying it. I did test drive it and boy, it will be fun to have a V8 Gave the sales guy a nice little ride (dude was holding onto the dash board the whole time)  |
Posted: Mon Jan 26, 2004 11:49 pm Post subject: |
What did the top of the engine look like? Was it TPI or TBI?
Was it like a carb setup looking or did it have 8 big silver runners? |
Roshambo Member
Joined: 08 Jan 2004 Posts: 280 Location: Sacramento, CA
Posted: Mon Jan 26, 2004 11:50 pm Post subject: |
Well.. if it is stock it would be TBI... visually TPI and TBI are real obvious and they didn't put TPI in the RS cars.
TBI and Carbs use the same style air cleaner assembly but its really easy to tell the difference between the two, just pull the lid to the air cleaner and you should see injectors on a TBI car.
Good luck and hope that helps!
-Joe _________________ 1970 Cadillac Sedan DeVille Hardtop - 472/TH400, Air Bags with 10 switches, Memphis Audio.
Posted: Mon Jan 26, 2004 11:55 pm Post subject: |
Cool, then I wasn't smoking crack... Must be TBI since it was set up pretty much the same was as a Carbed engine. Still a really nice, clean bright red car.
What is the posibility/difficulty level to switch to TPI? _________________ EGM: Who's that chick Mario is rescuing up there?
Brian: It's Princess Peach.
Kirk: It's a hooker.
Niko: She looks cut in half.
Tim: Oh wow—she's one of those pole dancers |
Posted: Tue Jan 27, 2004 4:21 am Post subject: |
| the switch isn't bad, but won't gain you anything. |
rice B-4 Member
Posted: Tue Jan 27, 2004 10:18 am Post subject: |
| It's not a LS6, but don't under estimate the TBI. |
Posted: Tue Jan 27, 2004 10:21 am Post subject: |
Justin, what did you put down? My 305 TPI peanut put down 180HP and 283lb ft. W/ headers and a lean condition.
If TBI IS right in with that, Go TBI.
I am going TBI on my jimmy when I find the parts. |
TecherB Princess B
Posted: Tue Jan 27, 2004 12:30 pm Post subject: |
whare did you find the car? (what part of town/dealership)
fine out if you can get any kind of service history on it.
get a car fax on it.
and if you do get it you should check the breaks and pull a valve cover before you think about up-grading anything. |
sllt1776 Member
Posted: Tue Jan 27, 2004 1:05 pm Post subject: |
well, it is possible to be an RS with TPI. if it has the B4C option. but that's rare.  _________________ Yup, I'm a traitor but I miss my 3rd gen.
Roshambo Member
Posted: Tue Jan 27, 2004 1:24 pm Post subject: |
| sllt1776 wrote: | well, it is possible to be an RS with TPI. if it has the B4C option. but that's rare.  |
Hmm, I didn't think about that... now that would be a find.
-Joe |
Posted: Tue Jan 27, 2004 1:27 pm Post subject: |
a real find is a 1LE/B4C car or an Original PlayersCup car.
ok, i will stop dreaming.... |
Posted: Tue Jan 27, 2004 1:32 pm Post subject: |
| rscamaro89 wrote: | ...nice, clean bright red car.  |
Muahahhaaha
My work here is done.
Next?
84transam383 Banned
Posted: Tue Jan 27, 2004 7:27 pm Post subject: |
| Schultzy89GTA wrote: | | rscamaro89 wrote: | ...nice, clean bright red car.  |
Muahahhaaha
Next?
-Schultzy | sure  |
Posted: Tue Jan 27, 2004 7:39 pm Post subject: |
Hehe, birdie with Camaro wheels. I thought that was a sin or something.  |
Midnight Sun Member
Posted: Tue Jan 27, 2004 7:44 pm Post subject: |
| rjmcgee wrote: | Hehe, birdie with Camaro wheels. I thought that was a sin or something.  |
If it is a sin to look damn good. Then yes it is.
I always though 'maro wheels looked great on birds.
But... biggest I see them is 15inch, and I am way into 17 inchers. _________________
84transam383 Banned
Posted: Tue Jan 27, 2004 7:46 pm Post subject: |
| rjmcgee wrote: | Hehe, birdie with Camaro wheels. I thought that was a sin or something.  | shhhhhh! be vewwwy vewwwy quiet,maybe they wont notice
there not permanent,there going on my 85 z,i was too lazy to swap off 12 wheels and tires lol,im undecided what kinda wheels are goin on my 84 .. |
Posted: Tue Jan 27, 2004 8:02 pm Post subject: |
I new I had this pic somewhere, I had to go find it.
The worst ever, 14 inch Firebird SE wheels on an Iroc.
sllt1776 Member
Posted: Tue Jan 27, 2004 8:32 pm Post subject: |
the sin is that it's red. _________________ Yup, I'm a traitor but I miss my 3rd gen.
Posted: Wed Jan 28, 2004 3:51 pm Post subject: |
| TecherB wrote: | whare did you find the car? (what part of town/dealership)
At Cars to Go on 82nd and BurnSide
Plan on getting a car fax on any car that I look at
I will try to get the service history
Breaks felt good and thanks for the heads up on pulling the valve cover. _________________ EGM: Who's that chick Mario is rescuing up there?
TecherB Princess B
Posted: Thu Jan 29, 2004 12:55 am Post subject: |
for the brake you want to know hoe much you have left on the pads and shoes so you might be able to tell how long until you will need new ones.
when you pull the valve cover you wnt to check for sludre build up how much. plus liik to see in any valve train parts are heavely watn including Valve springs have the been ofer heated and what do their seats looklike. |
