brake lights/ hazard flasher fuse issue
91camaro_rs
PostPosted: Sun Apr 17, 2011 7:45 pm    Post subject: brake lights/ hazard flasher fuse issue Reply with quote
so whenever i go to use my hazards, it blows the Power Acc. fuse. it did it twice today, yes i did need my hazards twice, and when it blows the fuse my brake lights go out as well
anyone have any input on what could be going on?
PostPosted: Sun Apr 17, 2011 7:49 pm    Post subject: Reply with quote
How'd you power your wbo2?
91camaro_rs
PostPosted: Sun Apr 17, 2011 8:14 pm    Post subject: Reply with quote
i had to take the wideband out, but i powered it using the accessory wire off the ignition, i had this problem for about a week or so now, its happened like 4 times, and it happened before the wideband was put in
PostPosted: Sun Apr 17, 2011 8:50 pm    Post subject: Reply with quote
Have you cleaned your sockets (including the 3rd brake light contacts) and tried swapping out bulbs?
91camaro_rs
PostPosted: Sun Apr 17, 2011 9:51 pm    Post subject: Reply with quote
no i havent, bulbs are still the same ones as when i got the car 3 years ago Laughing
would having dirty contacts on the brake lights cause them to blow the fuse when i turn on the hazards?
i didnt know they were connected
PostPosted: Mon Apr 18, 2011 7:12 am    Post subject: Reply with quote
That's a good question. I don't have a schematic in front of me but the light issues seem to be fixed by cleaning sockets and making sure the right bulbs are in there.
PostPosted: Mon Apr 18, 2011 7:57 am    Post subject: Reply with quote
If it doesn't do it with just turn signals its related to the hazard wiring. Take out the fuse and trace the short to ground.
91camaro_rs
PostPosted: Mon Apr 18, 2011 11:12 am    Post subject: Reply with quote
do i trace it using resistance w/ ohmeter?
PostPosted: Mon Apr 18, 2011 11:16 am    Post subject: Reply with quote
If you take a volt meter and put it on the load side, not the power in to the fuse..... and the other lead to ground.... you'll have continuity if there is a short. There should be some as the bulbs are grounded. So what you'd want to do, is start unplugging harnesses and or bulbs so isolate harnesses.
