Just ordered...
Goto page Previous  1, 2
PostPosted: Tue Apr 12, 2011 3:03 pm    Post subject: Reply with quote
it does seem to be sitting higher. Are you sure everything got seated properly when you put it back together?
PostPosted: Tue Apr 12, 2011 3:29 pm    Post subject: Reply with quote
Springs were out too. May take a bit to settle back down.
PostPosted: Tue Apr 12, 2011 3:35 pm    Post subject: Reply with quote
Ive watched a truck lower itself by just giving it an alignment.
Ive ordered my del-a-lums. So hopefully in a few weeks I'll have a similar setup.
PostPosted: Tue Apr 12, 2011 3:54 pm    Post subject: Reply with quote
...What? No I did the control arm bushings awhile ago. The only difference between those two pictures is about 2 weeks and 2 strut mounts. Smile
Only thing I did was swap strut mounts...
PostPosted: Tue Apr 12, 2011 3:55 pm    Post subject: Reply with quote
You'll love the del-a-lums!
How many years have Dan and I been telling ya'll that!
PostPosted: Tue Apr 12, 2011 3:57 pm    Post subject: Reply with quote
Laughing
Well I had made the presumption that poly were at least better than the rubber stockers. Not a chance. (at the time I did the polys I never even knew about delrin)
PostPosted: Tue Apr 12, 2011 3:59 pm    Post subject: Reply with quote
Don't worry Ian, I made the same mistake, and actually haven't had mine apart to put del-a-lums on. But I got to drive Dan's car at an auto-x event after he put them on his car, and it was a night/day difference.
RK82
1982 Pontiac Trans Am
PostPosted: Tue Apr 12, 2011 7:58 pm    Post subject: Reply with quote
I put del-u-lums in my car few weeks ago, so far all I've noticed is more road noise and a lighter wallet
PostPosted: Wed Apr 13, 2011 3:58 am    Post subject: Reply with quote
Actually, not very long Laughing I never knew about them when I replaced the stock bushings right after I got this car. But thats already been about 4-5 years. So its time to replace Very Happy
Ian, all I can guess is that your struts are doing more work then expected. And the stock rubber mounts were deflecting that much Shocked
PostPosted: Wed Apr 13, 2011 3:41 pm    Post subject: Reply with quote
So I had new tires mounted, cruised over to a buddy's shop for an alignment. Buddy calls me out into the shop a few minutes later and shows me I'm riding directly on the bumpstops in front. Probably why things felt stiffer. Laughing
Shaved the stockers down, who knows of some aftermarket short stops? Smile
PostPosted: Thu Apr 14, 2011 9:10 pm    Post subject: Reply with quote
Really? Maybe it was because my old poly bushings were so shot. What else is done to the suspension?
RK82
PostPosted: Fri Apr 15, 2011 6:46 pm    Post subject: Reply with quote
the front is completely stock except new balljoints, control arm bushings and bumpstops
PostPosted: Mon Apr 18, 2011 5:59 pm    Post subject: Reply with quote
del-a-lums have arrived. Very Happy
Picked up a press over the weekend. Rock on!
PostPosted: Mon Apr 18, 2011 8:42 pm    Post subject: Reply with quote
Maybe I'm wrong here but I'd tend to think that one solid part amongst a whole suspension of factory stuff maybe not have the same effect as the same solid set in an almost brand new solid suspension. Could be wishful thinking on my part that I wasn't wasting money though! Very Happy Laughing
RK82
PostPosted: Tue Apr 19, 2011 7:59 am    Post subject: Reply with quote
I guess I shouldn't say completely stock the tie rods, idler arm where all replaced with moog parts before I bought it, I believe the center link is still the original one but doesn't have any play in it, and its has KYB agx struts. the del-a-lum are defiantly a good product not a waste of money, plus there shiny and blue Laughing Burnout. now I can't wait for my Global West frame connectors and traclink to come in OOh look! OOh look!
PostPosted: Sat Apr 23, 2011 1:19 pm    Post subject: Reply with quote
Got my bushings in. On basic cornering I noticed a slight difference. I noticed it more in hard side to side transitions. I can also tell the tires are digging in a bit harder.
Anyone know what thread size the zerk fittings are? Appears to be metric.
Page 2 of 2
