91camaro_rs Member
Posted: Tue Mar 22, 2011 3:30 pm Post subject: |
ok im super confused now. i dont know which graphs under tunder pro to make adjustments too _________________
MrMike98 Member
Posted: Tue Mar 22, 2011 4:00 pm Post subject: |
welcome to the wounderfull world of ECM tuning............
the best way to BEGIN is to read the howto tune ecm articules in DIY PROM board on 3rd gen dot org. they are pretty much step by step .. AND its exactly the information your are looking for..
WBO2 is a must after basic tuning.....dyno would help, but we have some long steep hills that work almost as good..
good luck
Mike |
Posted: Tue Mar 22, 2011 4:35 pm Post subject: |
What ECM and setup are you running again? _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Wed Mar 23, 2011 10:42 am Post subject: |
730 Speed Density, 5.7 350 (bored 30 over) TPI _________________
Posted: Wed Mar 23, 2011 12:49 pm Post subject: |
MAP vs RPM table. That's your "BASE" map. All acceleration enrichment, power enrichment, etc run off that table. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Wed Mar 23, 2011 7:53 pm Post subject: |
so thats the one i adjust and doing that will result in a change in AFR eventually _________________
Posted: Wed Mar 23, 2011 7:54 pm Post subject: |
Yes. For that give RPM and Load/Map/kpa _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Wed Mar 23, 2011 8:03 pm Post subject: |
i looked on tuner pro and i dont see the Map vs RPm graph anywhere, im using the 8D.xdf _________________
Posted: Wed Mar 23, 2011 9:11 pm Post subject: |
| In is probably listed as VE 1 table, or main VE table. |
91camaro_rs Member
Posted: Thu Mar 24, 2011 8:55 am Post subject: |
If VE stands for Volumeric effeciency then i have 3 tables for it, one for up 1600rpm and one up to 5600 and one up to 6400rpm. _________________
Posted: Thu Mar 24, 2011 9:00 am Post subject: |
Those would be the ones.
Do they have a lot of overlap? usually you have one large table, that covers 0-100kpa and the rest of the tables are adder tables, that will cover RPM changes, and that are based on percentage changes to the main table.
Maybe I should just look at the 8d table setup, and let you know, lol. |
Posted: Thu Mar 24, 2011 10:15 am Post subject: |
How would I do the same thing Luke is trying to do with my MAF '165 in $6E? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Mar 24, 2011 11:24 am Post subject: |
| 91camaro_rs wrote: | | If VE stands for Volumeric effeciency then i have 3 tables for it, one for up 1600rpm and one up to 5600 and one up to 6400rpm. |
You've got the modded file with the extended VE tables. Wow. I can't believe I remember that.  |
Posted: Thu Mar 24, 2011 12:20 pm Post subject: |
RS- You get the lovely joy of editing your MAF Tables.
Basically lying to the ECM about the incoming air.
Power Enrichment is a calculated Load vs RPM. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 24, 2011 4:27 pm Post subject: |
Some guys on TGO were saying to mod the MAF Scaler tables and others said no, just the MAF tables. Which is correct?  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Mar 24, 2011 5:24 pm Post subject: |
I forget the different between the two.
IMHO MAF is pretty close everywhere but idle. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 24, 2011 6:06 pm Post subject: |
John, why are you trying to break things? Your car had near-perfect A/F on the dyno.  |
Posted: Thu Mar 24, 2011 9:22 pm Post subject: |
| aaron_sK wrote: | John, why are you trying to break things? Your car had near-perfect A/F on the dyno.  |
I still have the previous BIN. I'm just seeing what effect certain changes have on performance.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
91camaro_rs Member
Posted: Thu Mar 24, 2011 10:09 pm Post subject: |
ok cool, so on the VE tables how do i know what to change and how much do i change it? _________________
Posted: Thu Mar 24, 2011 10:15 pm Post subject: |
That is where the math comes in. But, since your at 160 BLM, you are WAY off, so you can do pretty good sized changes, 10-25% type changes.
If the BLM's get to 128, you got it right.
If they BLM's go under 128, you added too much
If they are still higher than 128, you didn't add enough. |
