Some Pics of the Audi Rebuild...
PostPosted: Sat Apr 02, 2005 1:11 pm    Post subject: Some Pics of the Audi Rebuild... Reply with quote
Its been going at a pretty slow pace, waiting for the machine shop, and parts, etc. I finally got started with putting her back together this weekend.
Here is what she looks like (and has looked like for the last month. All torn apart.)
Spent about 40 minutes with the Air tools, polishing the deck surface, so its all ready for the Cyl. Head.
Cyl. Head back from the machine shot. (lookin' good!)
Here I am, lubing up. (ohhh, that sounds dirty)
Once you lube things up good, you can slowly slide it in... (that sounded really dirty).
Head all back together, and ready to be put in the car.
So far, progress isn't as quick as I would have hoped. The Germans do things a little diffrently, so we are having to learn as we go.
(Barts favorite saying...)
John: Whats the torque spec on that?
Bart: Gutten-tight Laughing
Anyway, I thought I would share. I have a bit of a break, while I wait for Bart to get back over here, so we can fit the cyl head on the block, and install the ARP Head studs! From there things should go pretty quick, hopefully she will be running sometime this weekend. I'll post more pics later tonight.
PostPosted: Sat Apr 02, 2005 5:21 pm    Post subject: Reply with quote
Looking good John.
Someday you gotta try that lube up and slide in trick on a woman, has to be better than an Audi head. Pokey pokey
84transam383
Banned
PostPosted: Sat Apr 02, 2005 5:33 pm    Post subject: Reply with quote
he probably tried it on the last woman he had....
Laughing
PostPosted: Sat Apr 02, 2005 7:50 pm    Post subject: Reply with quote
Made a little more progress, but not as much as I planned. I was twarted by a 12point 1/2" deep socket, that is needed to torque down the nuts for the head studs. It is apparently a fairly hard to find socket.
Anyway...here are some more pics.
PostPosted: Sat Apr 02, 2005 9:20 pm    Post subject: Reply with quote
If you haven't already found a socket check Sears. I have a set of deep 12 pt sockets from Crapsman. Also the 13mm in my metric set from SnapOn would work, probably what is suposed to be used being a metric car and all.
Midnight Sun
PostPosted: Sat Apr 02, 2005 9:55 pm    Post subject: Reply with quote
Two cams... I am confused. Confused Confused Confused
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Sun Apr 03, 2005 3:34 pm    Post subject: Reply with quote
DOHC... It was breakthrough stuff. Hats off Dewster, you get the golden wrench award for this.
Facial hair...lubricants... deep sockets...your freaking me out man.
3:27 Borg Warner Posi K&N Filtration
PostPosted: Sun Apr 03, 2005 6:45 pm    Post subject: Reply with quote
Thats a nice bunch of spaghetti bolted to the side of that thing too.
Midnight Sun
PostPosted: Sun Apr 03, 2005 7:25 pm    Post subject: Reply with quote
Heh. If I know my audi's correctly. That manifold makes it so that the exhaust has the same distance to travel no matter what cylinder it is from. The stock manifolds are shorter inthe back, and longer in the front before reaching the exhaust. The spaghettit helps even it out and creates more even backpressure.
Dewey... how'd I do?
PostPosted: Sun Apr 03, 2005 9:09 pm    Post subject: Reply with quote
Pretty good.
You forgot to add, that it is a very rare factory header. Wink
Todays update:
Didn't get much done today. Torqued the head down (got ahold of a 12pnt 1/2" deep socket).
Went to put the timing belt on, and found this:
The keyway on the cam sprocket is broken. I'm actualy lucky I found this now. The I5 is an interferance motor, so the cams going out of time, could have been a disaster.
Midnight Sun
PostPosted: Sun Apr 03, 2005 11:06 pm    Post subject: Reply with quote
Pretty good.
I would have added that, but I didnt know it was factory. My buddy is getting one made for him for 450 bucks!
Insane. I am happy I drive a thirdgen where parts are plentiful.
PostPosted: Fri Apr 08, 2005 9:52 pm    Post subject: Reply with quote
Update:
Got the new cam gear today, and started putting it together again...
New Cam Gear, Timing belt also fitted.
Sealing up everything on the head.
Bart: "Gaskets, we don't need to stinkin' gaskets . . . we have RTV"
Timing belt cover, exaust and cover, and intake manifold on.
Here is where I left it for the night... Tomorrow, injectors, spark plugs/wires, and throttle body go on, along with the maf and air box. once thats on, I should be able to test fire it!!!!
PostPosted: Fri Apr 08, 2005 9:55 pm    Post subject: Reply with quote
Uber-iffic! Little german b**ch will be back on the road in no time.
Good job Dewmeister.
PostPosted: Fri Apr 08, 2005 9:58 pm    Post subject: Reply with quote
Schultzy89GTA wrote:
Little german b**ch
Shhh...don't talk like that...she might hear you.
PostPosted: Fri Apr 08, 2005 10:02 pm    Post subject: Reply with quote
Ohhhhh Embarassed
It was a term of endearment Very Happy
PostPosted: Sat Apr 09, 2005 5:24 am    Post subject: Reply with quote
For an Audi???
Shoot, for $450 i'd sell him mine. I have the turbo exaust manifold in my 'spare parts closet', for $450, i could buy the rest of the parts to convert it to a 20VT
PostPosted: Sat Apr 09, 2005 9:38 am    Post subject: Reply with quote
For an Audi???
Uh oh. Is dewey going to dyno a turbo audi? Very Happy
PostPosted: Sat Apr 09, 2005 9:44 am    Post subject: Reply with quote
AWD dude, I would take off the dyno like a rocket....lol
PostPosted: Sat Apr 09, 2005 6:09 pm    Post subject: Reply with quote
Ok... got quite a bit done today, then hit another wall Confused
The Good:
Cleaned up the TB, all ready to go on.
Started putting the intake back on, this task will make you swear in german.
Got the intake all done, and started on the wiring, and fuel lines, etc.
Basicly, completely assembled Engine!!!!
The Bad:
Battery was dead, so we had to try to jump it. Cranked it over just fine (engine turns, that is good!).
We found out, that one of my fuel lines is leaking. So the car will sit as it is until I get a new line. The other bad news, was it didn't fire. I suspect our timing is quite a bit off. Once the car stops soaking the engine bay in gas, i can try to get it timed.
Midnight Sun
PostPosted: Sun Apr 10, 2005 4:17 pm    Post subject: Reply with quote
For an Audi???
I am bringing him to P-town with me, you and him can talk.
OoOo, look at that header glow... Very Happy
