vega_guy_76 Member
Joined: 02 Jan 2005 Posts: 79 Location: St Helens, OR
Posted: Fri Apr 01, 2005 3:46 pm Post subject: Alright, Who sent the dyno curse my way? |
I got my Sprint all finished up about an hour ago and let it run up on the stands for about 30 minutes warming up and checking for leaks. An oil pressure gauge was also installed to check everything out. The good news is it's got great oil pressure with 75 psi at cold idle, 50-60 psi at a steady 60mph hot, and 24 psi at hot idle. The bad news is that at any steady speed at or above 60mph it is audibly knocking. The knocking goes away on acceleration and deceleration. Under 60mph it can't be heard. Needless to say, I wont be making the dyno with this "beast". lol.
So which would you rather see on the dyno?
1985 2WD Chevy Suburban with an '80-'86 Small Block Chevy... motor's origin is unknown.
Or,
2003 Pontiac Sunfire Ex-rental car, automatic
Charlie |
90droptoproc Member
Posted: Fri Apr 01, 2005 10:47 pm Post subject: |
sunfire with a 200 shot of spray  |
Midnight Sun Member
Posted: Sat Apr 02, 2005 12:01 am Post subject: |
| 90droptoproc wrote: | sunfire with a 200 shot of spray  |
It is an ex-rental car. I am sure it has seen a 200 shot before. _________________
Posted: Sat Apr 02, 2005 7:25 am Post subject: Re: Alright, Who sent the dyno curse my way? |
| vega_guy_76 wrote: |
Charlie |
Buying a used rental car is like going to a whore house to find a wife. She might not be that old but alot of people have rented her by the day. Not exactly something you want to go sticking your key in.  |
Sellmanb Member
Posted: Sat Apr 02, 2005 11:36 am Post subject: |
Charlie I'd love to see that Suburban of yours on the dyno. It sounded like it was mildly cammed.
Then again that Sunfire is probably used to being abused  |
84transam383 Banned
Posted: Sat Apr 02, 2005 1:20 pm Post subject: |
anything charlie owns/drives is used to being abused
that sucks charlie...i lvoed the sprint when i owned it
whats the plans with the motor now? drop in a srt-4 motor?  |
vega_guy_76 Member
Posted: Tue Apr 12, 2005 4:53 pm Post subject: |
I'm still debating on which vehicle to dyno, though I'm leaning more towards the Sunfire. I took the Suburban to PIR last Friday to see what it'd run and practice R/T's. And it turns out that the Suburban is slow... really slow. The best time of the night was 18.61 @ 70.12mph. Though it was fairly consistent in times:
18.61 @ 70.12
18.65 @ 70.47
18.74 @ 70.35
18.78 @ 70.07
18.82 @ 70.30
18.83 @ 70.44
18.87 @ 70.31
19.00 @ 69.67
Obviously those are not in the order they happened. Best R/T was .153 and worst was .226 *looks for sleeping smiley*. Best 60' of the night was 2.46 and the worst was 2.53. Good or bad, it's still really really slow. lol
The Sunfire on the other hand, has yet to be run at a track or with my G-tech. It may be interesting to see on the dyno. With it in 3rd it'll kickdown to second at anything slower than 65mph, which is right at 3,500rpm's. When it doesn't kickdown and the throttle is pushed to the floor the tach immediately jumps to 4,000-ish rpm and then should climb to the 6,500rpm redline. I expect at least a 16.9 1/4-mile time out of this car.
Current plans for the Sprint is that it's gonna sit untill I've saved enough to properly rebuild the motor. And when I stop spending money on the Vega, I just spent a hair under $500 in the last week on it.
Charlie |
Posted: Wed Apr 13, 2005 5:39 am Post subject: |
That's what the suburban ran?
I put down around 184 horse in my '67 C10 that weighed something like 4300lbs.... ran 16.xx in the quarter. |
vega_guy_76 Member
Posted: Wed Apr 13, 2005 6:13 am Post subject: |
| Twilightoptics wrote: | | That's what the suburban ran? |
That seems to be all it had in it. Pretty pathetic isn't it? I was expecting a low- mid-17 out of it. It's got 3.73 gears and will barely scratch the tires from a start. Maybe the engine's a 305 instead of the 350 I was told. Oh, the Suburban weighs around 5,200lbs.
Charlie |
Posted: Wed Apr 13, 2005 6:16 am Post subject: |
don't feel to bad, my camaro once went...
22.1 @ 92 |
ET phone hoME Member
Posted: Wed Apr 13, 2005 5:36 pm Post subject: |
| Dewey316 wrote: | don't feel to bad, my camaro once went...
22.1 @ 92 |
thats probably what mine would run  _________________ 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops. |
vega_guy_76 Member
Posted: Thu Apr 14, 2005 6:08 pm Post subject: |
LMAO... I think I found part of the problem. Today I did a basic tune-up on the Suburban replacing the cap, rotor, plugs, plug wires, oil, and oil filter. When I pulled the cap off, the rotor was just sitting there. It was NOT screwed down or even broken, JUST SITTING THERE! I knew the people I bought it from were rednecks, but come on! Tomorrow I may swap the q-jet carb and intake for a Weiand/Edelbrock combo. Possibly install headers too, not sure yet.
Charlie |
