Signs of a cat gutting itself?
BluFbdy
PostPosted: Sun Jan 09, 2011 11:17 pm    Post subject: Signs of a cat gutting itself? Reply with quote
Alright, so like the title says i need to know what the signs of a cat gutting
itself are, i was doing some work on the car today at work and i noticed metal flakes in the exhaust tips, my thing is though i was grinding on the passenger side (went to vaccum out the car, pulled my sub box and found a pool of water in the well!!!!!) i pulled the weather stripping off the hatch and found that the metal lip the seal attaches to rusted out in one spot letting water in, so i used duraglass and made a filler for the gap, i had to grind that down though so i thought at first that it was just the metal off that, but when i picked up the flakes they had a shine to them, not like normal metal grindings it kinda looked like fish scales, and i found them on the driver side tip as well.
on a side note theres been this weird noise coming from under the car ive been hearing for a few days now and after today im wondering if my cat is collapsing, if it is im just gonna hollow the dang thing out for now, when i was putting the exhaust together i put triangle flanges on each side of the cat so i can pull it out and just put a pipe in its place, problem isi never got around to making the pipe lol
so does this sound like a cat gutting itself? id rather hollow it out than have some awesome underglow from the thing heating up if it is
TIA
91camaro_rs
PostPosted: Mon Jan 10, 2011 12:06 am    Post subject: Reply with quote
never heard of a cat falling apart, only heard of them getting clogged, but what i did was i went to walts bought some pipe like 2 feet and i cut my cat off, used exhaust clamps to hold on the piece, then take it back to them and have it welded, they can weld a pipe, they just cant remove your cat, so if you do it yourself then its all good, thats when i had the v6 tho, my exhaust now has no cat its all one piece of pipe from collectors to muffler
BluFbdy
PostPosted: Mon Jan 10, 2011 1:44 am    Post subject: Reply with quote
Well its gotten banged up a bit lol it hangs down low and got punched a couple times in the snow lol even my factory exhaust would hang down like that so I dunno what's up, when I get my sfc's welded in by joey at LoCash ill figure out a better way to hang the exhaust lol I got my flanges and pipe from midas in az, had them weld on my flanges and such, my only issue is money is tight this month cuz I'm leaving for az so I'm takin a week off work, so for now ill just hollow the cat and get the pipe later on
PostPosted: Mon Jan 10, 2011 5:47 am    Post subject: Reply with quote
The inside of a cat is porcilin(sp) or ceramic. It would be little white pellets.
PostPosted: Mon Jan 10, 2011 8:04 am    Post subject: Reply with quote
I have seen a cat come apart and end up downstream. Had a piece of one stuck in the muffler of my little brother's car.
@ Jay: Ever punched one? They might start out white at the factory, but not after 25 years under a Chebbie. Laughing
BluFbdy
PostPosted: Mon Jan 10, 2011 8:49 am    Post subject: Reply with quote
Negative, I've never seen white pellets except in reaaaaally old cats, this one was a dynamax ( think that's the name, just woke up) high flow cat, I've seen them come out in chunks as mentioned above, never as white pellets, I'm on my way to the VA hosipital right now, ill pull the cat at work and take a look later
PostPosted: Mon Jan 10, 2011 9:39 am    Post subject: Reply with quote
They come apart all the time. Whack the cat when your fist and listen for rattles. Run the engine and listen at the cat for rattles. Rev it up and see if chunks come out. Often times they get stuck in the exhaust pipe and or muffler.
PostPosted: Mon Jan 10, 2011 11:07 am    Post subject: Reply with quote
Yep, Punched many of them. All tossed white pellets after that.
PostPosted: Mon Jan 10, 2011 11:11 am    Post subject: Reply with quote
The old chevy stuff was pellet based. The mid 80's up ones should be a honeycomb type.
PostPosted: Mon Jan 10, 2011 4:05 pm    Post subject: Reply with quote
It looked honeycomb. 2 I remember highly is an 85 s10, and 91 camaro.
BluFbdy
PostPosted: Mon Jan 10, 2011 5:44 pm    Post subject: Reply with quote
Yuuup it was toast, it fell out when I pulled it out from under the car lol
Oon a side note does anyone have a welder? That would either want to weld 2 flanges onto a pipe orrrr fill one hole for the air tube on the cat? Prefferably the second one since money is tiiiight right now
PostPosted: Mon Jan 10, 2011 6:38 pm    Post subject: Reply with quote
Fold the AIR pipe over 180Deg. It will seal pretty well.
BluFbdy
PostPosted: Mon Jan 10, 2011 7:09 pm    Post subject: Reply with quote
Tried that lol it snapped clean off it was cheap cast metal it snapped without hesitation
PostPosted: Mon Jan 10, 2011 8:12 pm    Post subject: Reply with quote
at the cat itself?
BluFbdy
PostPosted: Mon Jan 10, 2011 9:35 pm    Post subject: Reply with quote
Yeah I haven't had an engine bay tube for years lol
PostPosted: Mon Jan 17, 2011 10:32 pm    Post subject: Reply with quote
It probably won't cause you a problem. You might get some exhaust fumes if you turn of the AC and run on just your fresh air vents.
PostPosted: Mon Jan 17, 2011 10:40 pm    Post subject: Reply with quote
No no no... Exhaust leaks right under the car like that will smoke you out and party with your brain cells.
Come to think of it, maybe that's been my problem all along...
BluFbdy
PostPosted: Tue Jan 25, 2011 9:06 am    Post subject: Reply with quote
Yeah I'm starting to forget things more who knows lol just gotta toss in the straight pipe after everything levels out money wise, ill see if joey at lo cash can weld up the flanges when we do my sfc's, just gotta get a day off from work lol I took a big hit taking a week off to go to az lol
nonsensekid20
PostPosted: Tue Feb 15, 2011 6:56 pm    Post subject: Reply with quote
The guy I took my exhaust to didnt put a cat on.
and did it for really cheap. Soo if you need someone to take your car to for exhaust, thats the place to go.
Mike Sader's-American 1 automotive in puyallup. Nice job on the pipe too. Bigg fat welds. Twisted Evil
PostPosted: Tue Feb 15, 2011 7:04 pm    Post subject: Reply with quote
Well I hope he enjoys the big fat fine coming his way from the EPA because some kid narced him out on the interwebs.
