Cascade Crew Message Forums
flea Member
Posted: Sat Jan 29, 2011 11:09 am Post subject: Ford Taurus |
Ok, I know its not a third gen F body but I know you guys are wise and all knowing so I figured what could it hurt to ask.
1996 Taurus, no inst. Panel lights, no tail lights, no front, side or rear marker lights. Headlights work, brake lights work, turn signals work, and the lights on the buttons for power windows and locks work, as does the dome light. Checked all fuses and they are all good. Marker, tail, and inst. Lights are on different fuses anyway. They all quit at the same time. There must be some common link to them that I am missing. Any ideas on where to look, fusible link?? _________________ Killing mailboxes since 2009 |
Posted: Sat Jan 29, 2011 11:53 am Post subject: |
| They're actually all on the same circuit, but fused seperately afterwards. Beings the fuses are good, i'll take a bet that the headlight switch is bad. |
flea Member
Posted: Sat Jan 29, 2011 12:04 pm Post subject: |
Ok thanks, I'll check that _________________ Killing mailboxes since 2009 |
