9 Bolt Borg-Warner Posi Rear end
nonsensekid20
PostPosted: Sun Jan 16, 2011 2:31 pm    Post subject: 9 Bolt Borg-Warner Posi Rear end Reply with quote
Good or bad? Got a guy that has one for sale. Disc brakes included.
PostPosted: Sun Jan 16, 2011 2:45 pm    Post subject: Reply with quote
It's a stronger piece than the 10 bolt you have. What gears, options, miles, and condition is it in? And the most important question of all, what's the price?
nonsensekid20
PostPosted: Sun Jan 16, 2011 3:24 pm    Post subject: Reply with quote
I actually have no idea. lol. Comes with everything. Brackets, rotors, calipers, proportioning valve. Differential.
$400 bucks.
PostPosted: Sun Jan 16, 2011 4:10 pm    Post subject: Reply with quote
A little steep, but maybe worth it. figure out what the gear ratio is for sure.
camarokid
PostPosted: Sun Jan 16, 2011 4:41 pm    Post subject: Reply with quote
do it!
ive cooked 3 10 bolts..........never hurt my 9 bolt!
Camaro Kid
1969 camaro sport coupe resto project, 28,000 mi
nonsensekid20
PostPosted: Sun Jan 16, 2011 5:00 pm    Post subject: Reply with quote
Gotta save up 400 bucks. lol
PostPosted: Sun Jan 16, 2011 5:15 pm    Post subject: Reply with quote
If it's limited, and a decent ratio I'll buy it from ya. Wink
nonsensekid20
PostPosted: Sun Jan 16, 2011 5:52 pm    Post subject: Reply with quote
lol. its posi. 3.27 gears. anyone want to buy a open diff rear end? drum brakes. 3.23 gears i believe.
PostPosted: Sun Jan 16, 2011 5:56 pm    Post subject: Reply with quote
If you don't get it, forward me the guy's number.
That's a good ratio for an auto car, or one with a .70 T5.
nonsensekid20
PostPosted: Sun Jan 16, 2011 6:30 pm    Post subject: Reply with quote
Lol. I wanna get it. I just need like $200.
I've got a T5.
PostPosted: Sun Jan 16, 2011 6:37 pm    Post subject: Reply with quote
3.73 are better. 3.70 for a 9 bolt rather. Plenty of OD gear, but helps you take off faster with less clutch slip.
$400 for a complete good working order disc 9bolt posi is a good price.
PostPosted: Sun Jan 16, 2011 6:38 pm    Post subject: Reply with quote
If all you want is traction you can do that a lot cheaper by putting a 4th gen Zexel Torsen (1999-2002) limited slip in your stock housing. It's a type of mechanical locker that won't wear like a clutch posi. You can probably get one for $150. I sold one about a month ago for $110. I think shipping came to less than $30 out to Idaho.
nonsensekid20
PostPosted: Sun Jan 16, 2011 6:41 pm    Post subject: Reply with quote
Well I want the disc brakes too
PostPosted: Sun Jan 16, 2011 6:46 pm    Post subject: Reply with quote
It's not a hard job to swap the entire rear end housing. The most difficult part might be attaching the brake lines and cables.
PostPosted: Sun Jan 16, 2011 6:51 pm    Post subject: Reply with quote
Zexels are getting harder to find. When I bought mine for the Chevette, I ended up paying $200 for it cause it was the only one available local/ebay/etc.
nonsensekid20
PostPosted: Sun Jan 16, 2011 6:53 pm    Post subject: Reply with quote
I always thought Zexels went out easy.
Yeah rear ends are pretty easy. Brake lines shouldn't be too hard. Hopefully. hahaha
PostPosted: Sun Jan 16, 2011 8:20 pm    Post subject: Reply with quote
Confused Confused Confused Confused
nonsensekid20
PostPosted: Sun Jan 16, 2011 8:43 pm    Post subject: Reply with quote
Zexel Torsen's. I've heard they go out a lot and need to be replaced.
PostPosted: Sun Jan 16, 2011 9:03 pm    Post subject: Reply with quote
You may want to see how loose the cones are. They aren't exactly cheap to repair or rebuild. I have one that needs a rebuild and the cones machined.
And this site is helpful for parts.
http://www.9bolt.com/
nonsensekid20
PostPosted: Sun Jan 16, 2011 9:20 pm    Post subject: Reply with quote
If the cones are loose the differential is about to go out?
