Engine Revamp
izcain
9sec Club
PostPosted: Mon Dec 20, 2010 10:19 pm    Post subject: Engine Revamp Reply with quote
Well I think it may be time for another reincarnation for the Z powerplant
Engine is starting to have a rear main leak and the leak down test is giving me a little bit of the "You better reseal me" blues
Actually looking at taking out the 383 and changing bearings and rings (changing to hellfires) and putting it back together with a LOT better solid roller camshaft and valve train! I am starting to give up on the idea of trying to make a 9.9X pass on a hydraulic flat tappet........ I only had .49 more to go though dang it!
I will be posting pics as soon as I get the bug to tear it out (after Christmas has died down a bit!)
Just gotta make sure to have the car up and running before season now that there is no excuses not to travel with this nice truck and trailer in the driveway.
I should be able to up the kit to the 250 mark that way but my other idea is to change over all internals and go for the larger hit 250+ I am thinking though that this will cause mains to start walking around.
Based on a 3550 race weight with my fat behind in it a rough guesstimate is that the car makes around 600-10 ish just want to move it up a notch so that it will run a consistent 9.90 or so
Just thought I would let everyone know what im cookin up in the garage for this next season!
9.17 @ 148
PostPosted: Mon Dec 20, 2010 10:47 pm    Post subject: Reply with quote
Nice. Keep us posted man.
PostPosted: Mon Dec 20, 2010 11:02 pm    Post subject: Reply with quote
Sweet! I wanna see your car run at the track again! Cool
PostPosted: Wed Dec 22, 2010 11:35 am    Post subject: Reply with quote
Any way to reduce the weight? 3550 seems a little much. Might as well have a big block. Wink
PostPosted: Wed Dec 22, 2010 12:23 pm    Post subject: Reply with quote
3550 sounds great to me Sad
PostPosted: Wed Dec 22, 2010 12:24 pm    Post subject: Reply with quote
I'm with Travis. What all have you done to give the car a diet?
PostPosted: Wed Dec 22, 2010 12:28 pm    Post subject: Reply with quote
Don't get me wrong, I am all ears. It's just that mine weighs in 300lbs more than that. Big girl Wink
PostPosted: Wed Dec 22, 2010 12:32 pm    Post subject: Reply with quote
His is an 83?? So it should have the alumn front bumper already.
:edit: aftermarket glass hood
Lets see what else.
Schultzy, since yours is 89, it likely has a steel front bumper. But since your a bird, I dunno how much diff the bumper is. But I know the 82/83 birds also came with alumn. The camaros, the bumper swap is easy. Very Happy
PostPosted: Wed Dec 22, 2010 12:44 pm    Post subject: Reply with quote
Wow. That's even more than mine! Although you've got the full interior, stereo, AC and all those fancy controllers and boxes. Very Happy
PostPosted: Wed Dec 22, 2010 3:09 pm    Post subject: Reply with quote
didn't you know? All the weight in our cars, is in the roof structure. Wink
PostPosted: Wed Dec 22, 2010 3:24 pm    Post subject: Reply with quote
Ok, in fairness, that was with me in it. Without me she weighs in about 3200 lbs.
Very Happy
PostPosted: Wed Dec 22, 2010 9:37 pm    Post subject: Reply with quote
Whoa. A 550lb Schultz. You been eating a lot since I've seen you? Very Happy
Maybe with the rear glass!
izcain
9sec Club
PostPosted: Wed Dec 22, 2010 10:22 pm    Post subject: Reply with quote
Well actual weight is 3350 which gives away how much extra fat is getting hauled around haha Embarassed
Car has the impact bumpers in the front and rear removed and the bracing has been shaved down to just two sections that hold the park lights under the fascia car has a glass hood and removed all interior panels and seats in the rear. carpet is still there.
Gotta remember most of you guys dont have a full cage either though! that was a lot of extra weight!
I actually should reweigh the car now that I think about it because I have since changed alot of suspension components and rims and tires so it I really have no clue lol
Last time I weighed the car was with what was listed above but with the heavier tires and rims as well as stock suspension.
Maybe 3200 is a more acurate weight........ I will find a scale and let you guys know.
9.17 @ 148
PostPosted: Thu Dec 23, 2010 5:02 am    Post subject: Reply with quote
I agree the cage is throwing our minds outta wack.
I'm sure I'm about to list a few things your going to say "duh" about, but just ideas.
1. I'm sure the ac is gone, what about box on the wall, and ducting behind dash?
2. guessing you decided to keep carpet for a reason. But remove the padding on the back. What about trunk carpet?
3. What about dash pad? on 91/92 that thing is metal supported and heavy!
4. Knee panel under steering column? Again, 91/92 its metal lined.
5. Are wipers needed in your class?
6. What about the plexiglass headlight covers. Its added weight, but may help the wind flow over the lights rather then be a wind drag.
7. Was reading this weekend how much "moon caps" can save mpg on semis due to wind drag. May look at them for the rear tires if you can keep the on at 100+mph?
8. remove rear deck spoiler. 7lbs of doesnt do jack crap.
Then I think it may be time to look into the lexan back glass if your class suports it.
izcain
9sec Club
PostPosted: Thu Dec 23, 2010 7:19 am    Post subject: Reply with quote
1. It's a no ac car but it does still have the box with the heater core still in it. I have found a company that makes a delete panel so that you can remove the box and everything that's with it. I figure that might be good for some weight.
2. Actually the whole front part of the interior is intact...... did that just for creature comfort for what very little driving the car gets on the road but it may be time to start thinking about going faster instead.
3. That is a good idea but I guess you would have to fab some sort of bracket to hold the dash pad up properly? could be done but I will have to take the pad off and get a good look at it (should do that at the same time I remove all the ducting and heater box lol)
4. I know the panel under the column is metal as well. Another thing I will look at!
5.Wipers are not needed but again I had only kept them on for the occasional drive for the just in case rain happens (not that it ever rains in Washington haha ) But then again I only bring the car out in summer so it is never going to see rain who am I kidding lol
6. the light covers may be a good idea I have seen the font ends at high mph they are all distorted up.
7. I dont think I Would wat to drill the holes in to my billet specialties street lites for moon caps lol some things arent worth the speed haha
8. I will have to find the article but that spoiler was tested and while we may never know the difference it is putting a certain poundage of down force on the car. I will have to find the article to see how much it was.... IT wasn't much...... I figured I would leave it until im going fast enough to warrant a drag spoiler off the rear (not going to happen for a while!)
I have looked into the lexan hatch. I know this would probably be the best thing off all since I remember when I pulled the hatch that dang thing was HEAVY!
Thanks for the suggestions!
9.17 @ 148
PostPosted: Thu Dec 23, 2010 8:19 am    Post subject: Reply with quote
I thought this was an all out drag car and never used on the street.
As for the moon caps, I think they may just snap on like hubcaps? But wonder if the air pressures would pop them off at 100+.
Anyway, just tossing ideas out.
izcain
9sec Club
PostPosted: Thu Dec 23, 2010 5:10 pm    Post subject: Reply with quote
Yea the car up until recently has been a street driven ride (summer time) but the faster it has been going the harder it is to keep it on the street without having other issues. I will always drive it on the street once in a while that is a given though even without a heater Very Happy It is just fun to pull up to the local cruise in and they know the car is capable of deep tens
Yea I forget but I think that slicks grow like 1 inch for every 100 miles and hour or something like that I for get the rule of thumb.
9.17 @ 148
IROCDave
PostPosted: Thu Dec 23, 2010 5:58 pm    Post subject: Reply with quote
Must be difficult to decide between street driving and pure dragstrip performance.
Have you looked into more cubes? If your planning for a larger shot you would be looking into a new rotating assembly also, shouldnt cost much more to add displacement?
izcain
9sec Club
PostPosted: Thu Dec 23, 2010 8:57 pm    Post subject: Reply with quote
Nitrous or boost is a great equalizer.
388 or 393 is about the max your gonna get without getting into heat spotting issues with the ol 010 block and the 393 has a crappy rod to stroke ratio for what im doing. Thought about going for a 400 and going 434 but that would be expensive and the blocks are weaker.
If I can get it to 9.xx I think I Will leave it alone for awhile (just perform the normal freshen ups) which should be obtainable with only minor changes to the current combo.
9.17 @ 148
PostPosted: Sat Dec 25, 2010 2:16 pm    Post subject: Reply with quote
How much does a cage weight? I've never had one so I have no clue. I keep playing with the idea but the added weight just kills me. And once you cage it, can you remove interior structures like inner roof supports? I think you can gut the doors if you have side impact bars, please correct me if I'm wrong. I know doors weight a ton!
3350 isn't too bad at all. I'd say your doing good.
