Posted: Tue Nov 02, 2010 11:08 am Post subject: Quadrasteer? |
How feasible would it be to think taking one of the gm half ton truck quadrasteer axles (circa 04-05) and mounting it up under a thirdgen? I'm not too familiar with them but I was thinking about this while talking to a quadrasteer owner the other day. I'm fairly certain you'd need to cut out where the back seats are, or at least a chunk, to fit the steering rack. But I guess that means a torque arm would be hard to mount. Flip the knuckles and mount the rack on the rear? Then the panhard becomes an issue...
I guess I'm just babbling.  _________________
Posted: Tue Nov 02, 2010 11:56 am Post subject: |
GM actually made a few demo thirdgens with rear steering. From what I remember, they flipped one on the skidpad, so they trashed the whole idea.
I remember seeing a pic of the 1 they kept on a rack and showed the rear wheels turned. _________________ 2008 GMC Z71
Posted: Tue Nov 02, 2010 12:04 pm Post subject: |
Is this a passive type steering?
If so ditch that idea. Everyone I've ever known to have passive rear steering, when a component fails, they remove it. It's a bad design and bad idea. _________________ A redline a day keeps the carbon away! |
Posted: Tue Nov 02, 2010 8:22 pm Post subject: |
It's ECM-controlled? How are you gonna hook all that up? Also, how is this:
...going to ever physically fit under your car? Not to mention the width. And it's not like you can just whack a section out, reweld the tubes, and cut a little off of the splined ends to narrow it down, either. |
Posted: Tue Nov 02, 2010 8:57 pm Post subject: |
| Twilightoptics wrote: | Is this a passive type steering?
If so ditch that idea. Everyone I've ever known to have passive rear steering, when a component fails, they remove it. It's a bad design and bad idea. |
No it's active. From what I understand low speed steers opposite driver input for sharper turn-in and higher speed (don't know the cutoff?) steers the same as driver input for stability during lane changes and such. There's a button on the dash so I would presume you can turn it off or on.
| aaron_sK wrote: | | It's ECM-controlled? How are you gonna hook all that up? |
Yes, however I would think the control module for it uses a steering angle sensor and speed input. What else would it need?
| aaron_sK wrote: | Also, how is this:
I think fitting under the car wouldn't be as difficult as making room for the 2-3* steering change or whatever it does. What's a thirdgens track width?
Why couldn't you cut/shorten the tubes? Use shorter TREs. With the rack mounted to the diff you don't have to worry about bumpsteer. |
Posted: Tue Nov 02, 2010 10:35 pm Post subject: |
| It took GM several years to get the software right. The hardware wasnt a big issue. It's basically all front end stuff from a 4x4. The big problem was knowing when to turn how much while keeping the vehicle stable. |
IROCDave Member
Posted: Wed Nov 03, 2010 6:55 pm Post subject: |
| My wifes brother in law has a GMC 1/2 ton with it. There is no way in hell you could fit all of the hardware needed for this diff in a 3rd gen. It is amazing what GM stuffed under those trucks, it's more congested than if they had put independent suspension in it. The rear end is also about 6" wider than the regular truck rear end. If I remember correctly, this was promoted as a towing aid and the diffs were all 14 bolts. They are huge. |
Posted: Wed Nov 03, 2010 7:09 pm Post subject: |
| IROCDave wrote: | | My wifes brother in law has a GMC 1/2 ton with it. There is no way in hell you could fit all of the hardware needed for this diff in a 3rd gen. It is amazing what GM stuffed under those trucks, it's more congested than if they had put independent suspension in it. The rear end is also about 6" wider than the regular truck rear end. If I remember correctly, this was promoted as a towing aid and the diffs were all 14 bolts. They are huge. |
They're actually a modified dana60. And I agree that the dana60 stuff probably wouldn't fit very well. (the quadrasteer burban's can be picked out by the red/amber clearance lights all down the side. They're wide enough to to be required.
The experimental rear steer thirdgen used a dana44 housing and front s10 knuckles so I'm sure that could fit... |
Posted: Thu Nov 04, 2010 11:02 am Post subject: |
| Not that I doubt you Ian, but where did you find that info? I had looked before on the internet and couldnt find anything. I remember the info from a hotrod mag, or some type of mag. |
Posted: Thu Nov 04, 2010 11:34 am Post subject: |
| 91RSVert wrote: | | Not that I doubt you Ian, but where did you find that info? I had looked before on the internet and couldnt find anything. I remember the info from a hotrod mag, or some type of mag. |
What info? As much as I detest TGO, it was there.
http://www.thirdgen.org/techboard/fabrication/564909-aws.html
I already forgot where I found the dana60 info... I'll find it when I get back from work. |
Posted: Thu Nov 04, 2010 12:14 pm Post subject: |
| This sounds like a good way to have your car torn apart for a 5-10 years.. |
Posted: Thu Nov 04, 2010 2:59 pm Post subject: |
| chevymad wrote: | | This sounds like a good way to have your car torn apart for a 5-10 years.. |
Naw, that is what big block swaps are for.
Posted: Thu Nov 04, 2010 8:30 pm Post subject: |
I've got my eye on another thirdgen. No need to down my daily for that long. |
Posted: Thu Nov 04, 2010 8:38 pm Post subject: |
So instead of messing with all that electrical and software crap.. you could put a steering wheel in the backseat and let Dirty Steve drive....
Or not.  |
Posted: Thu Nov 04, 2010 8:48 pm Post subject: |
Yeah...about that... no thanks. |
Posted: Thu Nov 11, 2010 2:22 pm Post subject: |
I love the quadrasteer silverados. Parking lots and U-turns are easy as pie with those trucks. It also eliminates the need for making a 3 point turn to get in on a rack. I can ask some of our techs some questions about the whole system if anyone wants. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
