91camaro_rs Member
Posted: Mon Nov 01, 2010 11:46 am Post subject: Motor Swap II |
i thought i would make a thread documenting my 2nd motor swap haha
ill also post any questions i have or problems i run into here to prevent multiple threads
picked up the motor saturday.....LONG DRIVE! lol
the engine is now on a REAL engine stand haha unlike last time when i used 4x4 fence posts. and im working on cleaning it up and getting it painted
Posted: Mon Nov 01, 2010 2:54 pm Post subject: |
| Eww.. nasty hard dirt inside the engine. Try to blow all that crap out without getting it down in the pan if you can. Once you have that clean pour a few gallons of diesel through and drain it. .Trying to rinse out any garbage that might have made it into the pan. |
91camaro_rs Member
Posted: Mon Nov 01, 2010 4:11 pm Post subject: |
I. Thought roller motors had roller rockers...? _________________
Posted: Mon Nov 01, 2010 4:19 pm Post subject: |
| No.. i think only vettes got roller rockers in any of their motors. Not sure bout LS stuff. Roller motor just means roller lifters.. the most important part. |
91camaro_rs Member
Posted: Wed Nov 03, 2010 8:23 am Post subject: |
ok so when i lift up my motor with a hoist i use an engine leveler that bolts to where the intake manifold bolts onto, should i wait until after the motor is in the car to install the manifold because i have to remove four of the bolts to put the leveler on? or should i just go ahead and put manifold on?
and should i find another place to mount my coil? considering everytime i need to adjust timing i have to unbolt the coil bracket which is bolted down with one of the intake manifold bolts
im just thinkin that its probably not a good idea to undo the bolts but who knows maybe the other 8 bolts are enough to keep it sealed while i get it in the car and adjust timing _________________
Posted: Wed Nov 03, 2010 8:30 am Post subject: |
You can undo the 4 bolts from the intake to install the motor no problem. Just make sure you torque the intake down properly with all 12 first. Then use longer bolts for the leveler. I like to have the intake on if I can because it helps keep debris from entering the motor. My HSR however, I put on after the motor is in simply because of how tall it is and it's installed as a unit with the injectors already on.
You can move your coil anywhere you want. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Wed Nov 03, 2010 9:03 am Post subject: |
alright cool, thanks  _________________
Posted: Wed Nov 03, 2010 12:14 pm Post subject: |
My coil is right above the dizzy mounted to the firewall. I have to remove it any time I do a tuneup Wasnt the smartest place. |
91camaro_rs Member
Posted: Wed Nov 03, 2010 1:26 pm Post subject: |
91camaro_rs Member
Posted: Wed Nov 03, 2010 2:38 pm Post subject: |
ok so the intake manifold i got from john is the wrong one....i need the one that has the middle bolts going almost straight up and down, i have the one where they are all the same angle _________________
Posted: Wed Nov 03, 2010 2:59 pm Post subject: |
You can get some beveled washers from Tacoma Screw for ~$1.5/pc. I did that when I put my HSR on. You have newer heads and older manifold, correct? IIRC it's something like 15* bevel? It's off by a degree or two but I never had any issues in the few years I had my HSR on.
Or are you going the opposite direction? Old heads and newer manifold? I can never remember which had which. _________________
Posted: Wed Nov 03, 2010 3:24 pm Post subject: |
Just posted in your wanted ad.
Die grind the 4 center holes to fit. And like Ian said, get some beveled washers. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Wed Nov 03, 2010 3:37 pm Post subject: |
ok so the LG4 in my car now has a newer manifold on old motor
the L03 is new motor and i have an old manifold
i could just swap them when i pull the motor but the newer manifold i have has a bad water neck bolt hole, i have some huge screw in there now and it works but i like to have things right ya know
whats a die grinder? _________________
90droptoproc Member
91camaro_rs Member
Posted: Wed Nov 03, 2010 3:57 pm Post subject: |
will it work if i use one of those in a drill?? _________________
90droptoproc Member
Posted: Wed Nov 03, 2010 4:05 pm Post subject: |
| ya if you hang on tight, or even a dremel would work |
91camaro_rs Member
Posted: Wed Nov 03, 2010 4:12 pm Post subject: |
ok cool _________________
91camaro_rs Member
Posted: Wed Nov 03, 2010 4:19 pm Post subject: |
i did work on this thing today, got it cleaned, painted, installed cam, set valve lash, and figured out intake is wrong lol
Posted: Wed Nov 03, 2010 8:46 pm Post subject: |
as paul said.. just elongate the center intake holes on your TPI manifold. with proper gasket and some teflon sealant around the intake bolts, should be no issue. _________________
Posted: Wed Nov 03, 2010 9:26 pm Post subject: |
| chevymad wrote: | | i think only vettes got roller rockers in any of their motors. |
Yup, LT4 exclusive.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
