Posted: Wed Feb 23, 2005 7:32 pm Post subject: |
| As you know everything flows downhill. Usually the back cylinders flood out because the motor is tipped towards the back and all the excess fuel just runs into them. Depending on manifold design some runners being lower then others can also have the same effect. |
90droptoproc Member
Posted: Wed Feb 23, 2005 9:04 pm Post subject: |
| WOW that totaly answered an old question for me, thanks Chevymad |
laegion Member
Posted: Fri Feb 25, 2005 6:37 pm Post subject: |
well, the oil was definately filled with gas, checked spark on all of the dead cylinders and the spark is quite strong, I pulled off the carb and opened it up and didn't find any dirt, but I blew it out with an air compressor anyway, so now I just need to find some rebuild specs for the carb to adjust the float properly and put it back together and cross my fingers and hope it works.
has anyone had their rear main seal leak when they first start an engine and then stop leaking after the motor has been run for awhile? _________________ 95 vw jetta gl
currently looking for a cheap ninja 250 or 500 or comperable 2cyl sportbike. |
laegion Member
Posted: Thu Mar 10, 2005 8:31 am Post subject: |
well, the trans am started up last night, on all cylinders and sounds evil, but that's probably mostly because it's running open headers, time for some exhaust.
Thanks Everyone! _________________ 95 vw jetta gl
Wolffy Member
Posted: Thu Mar 10, 2005 9:37 am Post subject: |
so rebuilding the carb fixed it ??
i agree its nice to hear them run
just got mine running last night |
90droptoproc Member
Posted: Thu Mar 10, 2005 11:52 am Post subject: |
| glad to hear it's working now!! |
laegion Member
Posted: Thu Mar 10, 2005 12:27 pm Post subject: |
| Wolfy's_88IrocZ28 wrote: | so rebuilding the carb fixed it ??
i didn't rebuild it, just took it apart and made sure everything was adjusted properly, then re adjusted the valves again, and set timing, adjusted the idle and aired out the wet cylinders. _________________ 95 vw jetta gl
