still having problems with code 43...
jakemk8706
PostPosted: Tue Sep 21, 2010 8:22 pm    Post subject: still having problems with code 43... Reply with quote
so the car still runs terribly after a new icm and a new knock sensor. it barely revs and it back fires a lot. i have no idea what the hell is going on with it. any other suggestions?
gas brake dip dip
PostPosted: Tue Sep 21, 2010 10:14 pm    Post subject: Reply with quote
How did you install the knock sensor?
If it's in too far it will be over sensative and the ECM will pull all kinds of timing out.
jakemk8706
PostPosted: Wed Sep 22, 2010 10:40 am    Post subject: Reply with quote
well i screwed it in until it was more that snug, it felt like it was about to bottom out so i stopped tightening.. there was still threads showing on the knock sensor when i was done tightening it tho. do you think i should try backing it out some? if so how much would you recommend? like just past finger tight or something?
gas brake dip dip
PostPosted: Wed Sep 22, 2010 1:14 pm    Post subject: Reply with quote
Yeah, you've got that bugger in WAY too far.
It's some small little spec. Look it up in the repair manual.
Honsely I screw them in just until I feel it wont leak coolant. You'll need to drain the coolant and reseal it too if you back it out from here.
jakemk8706
PostPosted: Wed Sep 22, 2010 3:35 pm    Post subject: Reply with quote
Ya that's weird. The installation procedure from my Haynes manual says "intsallation is reverse as removal" so I'll try backing it out and see what happens. Thanks
gas brake dip dip
PostPosted: Wed Sep 22, 2010 7:32 pm    Post subject: Reply with quote
If you're using the Haynes aftermarket manual, the torque specs will be listed at the beginning of the chapter, not in the article itself.
The torque spec is like 14-15 ft lbs, IIRC, basically just barely wrist snug.
