90droptoproc Member
Posted: Sat Feb 26, 2005 1:21 am Post subject: 02 sensors |
would the 02 sensor from a 2.8 or 3.1 mpfi motor be the same as the one for my 91Z 350TPI?
thanks in advance
Rich |
Posted: Sat Feb 26, 2005 8:03 am Post subject: |
| Not sure, but get a Delco. I lost 2mpg when I took out an old ACdelco in my 4.3L Jimmy, and put in a new Bosch. |
laegion Member
Posted: Sat Feb 26, 2005 8:46 am Post subject: |
yes they are the same _________________ 95 vw jetta gl
currently looking for a cheap ninja 250 or 500 or comperable 2cyl sportbike. |
CheezX Member
Posted: Sat Feb 26, 2005 9:08 am Post subject: |
| Yeah, the Bosch ones are crappy, go Delco or NGK. |
90droptoproc Member
Posted: Mon Feb 28, 2005 11:23 pm Post subject: |
so I should be ok useing the one from a 2.8 corsica?
thanks for all the replies guys |
CheezX Member
Posted: Tue Mar 01, 2005 12:34 am Post subject: |
| lol, I didn't figure out it was you rich, until I saw your post on the other thread. 2.8 sensor should work, if you need I have a whole bunch of heated O2s with the heater burnt out. They would work just fine for you since you still have stock manifolds. |
90droptoproc Member
Posted: Tue Mar 01, 2005 8:42 am Post subject: |
| thanks cheez! |
