New Throttle Body
Darbbackwords
New Member
PostPosted: Sat Sep 04, 2010 11:13 pm    Post subject: New Throttle Body Reply with quote
So I finished doing a bunch of little things to my camaro. One of which was cleaning the throttle body and IAC. It was sticky at/near an idle which made it difficult to drive around.
After cleaning, apparently some of the dirt was taking up space in the "slop" that is in the throttle body bushings. So now that it is clean, it will stick with a lot of the gas pedal. I thought I was going to get to drive it today, but as I was leaving the driveway the throttle stuck and my RPM's went up to 4500, so I parked it. Crying or Very sad
So, does anybody have a good throttle body for cheap or do I get to buy a new one?
~Brad
PostPosted: Sat Sep 04, 2010 11:16 pm    Post subject: Reply with quote
Are you sure you didn't just crap the spring up?
Darbbackwords
New Member
PostPosted: Sun Sep 05, 2010 12:07 am    Post subject: Reply with quote
Pretty sure, works great when the car isn't running. For some reason when running it jams. With it off the car there is a noticeable 1/8 inch of play in the shaft. With a quick throttle blip it returns back to idle, but when slowly released it jams.
PostPosted: Sun Sep 05, 2010 9:03 am    Post subject: Reply with quote
Lube. Remove the cables and verify it's the blades sticking and not a cable somewhere.
PostPosted: Sun Sep 05, 2010 9:29 am    Post subject: Reply with quote
Pretty common for the shaft to be worn so that vacuum pulls the blades up against the side of the throttle body.. Jams it right off idle. After that its fine.
As everyone says, make sure everything else is kosher first though.
Darbbackwords
New Member
PostPosted: Sun Sep 05, 2010 10:59 am    Post subject: Reply with quote
I have removed the cable and it only jambs under engine vacuum. First thing I tried was spray tons of lube in there, and over all the pivot points, worked it around for a while, then toweled off the excess with no results.
