91camaro_rs Member
Posted: Thu Sep 02, 2010 9:54 pm Post subject: tach just started spazzing |
so today i was driving and my tach started acting up, it did this before but only after 3k rpms, now it does this no mater what
here is a video of what it is doing
http://s164.photobucket.com/albums/u11/tomcatpilot15/?action=view¤t=Video-0010.mp4
any ideas on how to fix?
i do have resistors wired to the chip to do the tach fix, but when i was data logging the tach read 250 rpms low. i also have a spare tach to swap if thats what i need to do. |
Posted: Thu Sep 02, 2010 10:07 pm Post subject: |
Crap up about the time you were messing with the pigtails on the coil, did it?  |
91camaro_rs Member
Posted: Thu Sep 02, 2010 11:10 pm Post subject: |
it was fine till i hit 80mph down a hill...
did some research on TGO, and im using a V6 tach chip on a v8 car, with v8 amount of resistance, and so the chip is supposed to v8 one (4 pulses per revolution.)
looks like i need to get a v8 tach chip, or just a v8 cluster |
BluFbdy Member
Posted: Tue Sep 07, 2010 8:33 pm Post subject: |
im not sure about the datalogging part but mine started doing something similar after i messed with the cluster, i replaced the normal bulbs with LEDs/resistors i soldered together and stuck back in, but my tach was doing the awesome dance after i hit a bump, it did it constantly and was off by a few hundred rpms, idling it would bounce to the music that was playing lol Turns out the cluster wasnt seated against the connector properly, do you think you could have bumped it loose? i just pulled my cluster and put it right back in and now everything works perfectly fine
was it working alright before? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
