Rear Alignment
Leejo2005
PostPosted: Sun Aug 29, 2010 12:09 pm    Post subject: Rear Alignment Reply with quote
So I have installed new adjustable LCAs and pan hard bar, and messed up the front alignment. Where's a good place to get a 4 wheel alignment? I figure most places might not have specs on hand to do this, or will a standard thrust alignment be sufficient?
2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383
PostPosted: Sun Aug 29, 2010 1:30 pm    Post subject: Reply with quote
Just set the LCAs at the same length centering the wheel in the tire well and the slip yoke at the right ride.
The panhard you adjust so the rear is centered side to side. It's not an exact science.
Then just get a front end alignment.
