GREG DAVIDSON Member
Posted: Tue Aug 24, 2010 3:23 pm Post subject: Intake questions.... |
No this has nothing to do with my brothers post . Schools coming up and I see some expendable cash again soon for my engine. I was wondering what your opinions might be on twords carb or tbi set up. I found this that kinda looks interesting to me, http://www.holley.com/550-401.asp
And the cam i have says no computers would this rule something like this out ?? If need be I can re look up the specs on my cam. |
Posted: Tue Aug 24, 2010 3:53 pm Post subject: |
Any cam that is not stock, ESPECIALLY in a MAP application will need tuning to run close to right.
Don't bother with TBI if you're building a hotrod motor. Don't even bother with TPI unless it's for torque for a truck.
Carb or aftermarket Port Injection.
Holley's stiff is sweet. But I still think it's dumb to have the injector ontop. You Can't get the proper atomization idle/cruise especially for nastier setups to make it worth my while. Sure it'll work, just not as efficient.
Cam saying no efi means no stock efi. You can tune anything. Look at Mike and I. _________________ A redline a day keeps the carbon away! |
Posted: Tue Aug 24, 2010 3:59 pm Post subject: |
| Thats what i kinda thought on the computer question thanks. So either multi port or just the carb they have this http://www.holley.com/550-811.asp , but at that price I probably just stick with a good carb |
Posted: Tue Aug 24, 2010 4:20 pm Post subject: |
Or get the computer and look for a deal on any aftermarket port manifold. Holley uses all GM sensors. So TPI sensors will work etc. _________________ A redline a day keeps the carbon away! |
91camaro_rs Member
Posted: Tue Aug 24, 2010 11:55 pm Post subject: |
| i agree, camming a motor with map needs lots of tuning and has to be darn near perfect to run at all... my car still needs a good tune |
Posted: Wed Aug 25, 2010 12:07 am Post subject: |
| Twilightoptics wrote: | | Or get the computer and look for a deal on any aftermarket port manifold. Holley uses all GM sensors. So TPI sensors will work etc. |
Doing that will only save you what, 4-500 bones off of the two grand sticker price, though. Holley wants your left nut for their ECM's.
If you're just gonna run a mild smallblock, why not find a cheap used StealthRam, run a stock Chebbie ECM, and burn your own chips.
*two cents* |
Posted: Wed Aug 25, 2010 1:09 am Post subject: |
Thats fine Aaron I want everyones two cents . Figured you guys have been at this a bit longer than me and know a crap load than me specially about the computer setups. So I like the idea of used parts mainly cause in poor if i wanted to start tracking down parts could you give me a mini checklist of stuff i may need. |
Posted: Wed Aug 25, 2010 3:09 am Post subject: |
| Is the 305 TPI intake and plentum much different than the 350 ? If not then I think i need to hit up doubletake. |
Posted: Wed Aug 25, 2010 4:34 am Post subject: |
TPI parts are all the same for 305/350 except the injectors.
You do have differences between the years. Also some of your vette parts wont work with camaro parts. Mainly the fuel rail. _________________ 2008 GMC Z71
Posted: Wed Aug 25, 2010 8:26 am Post subject: |
| 91RSVert wrote: | | TPI parts are all the same for 305/350 except the injectors. You do have differences between the years. |
You can ask John about differences between the early and late Tuned Port intakes.
Don't run TPI on your 327. Like Paul said, don't run TPI on anything but a big truck or a big land-yacht. Shifting at 4500 is very overrated. |
Posted: Wed Aug 25, 2010 12:24 pm Post subject: |
Gotcha  |
Posted: Wed Aug 25, 2010 4:05 pm Post subject: |
| aaron_sK wrote: | | 91RSVert wrote: | | TPI parts are all the same for 305/350 except the injectors. You do have differences between the years. |
I've got the TPI Swappers Guide for piss sake! Its not like I didn't know there was a difference, I just used the wrong runners. But thats the beauty of having a complete early and late setup to grab parts from!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Aug 25, 2010 4:55 pm Post subject: |
So John, your argument is that you were not uninformed, you were just being retarded?
BTW, not only did you use the wrong runners, but you also used the wrong upper plenum. I know this because James and I where the ones who fixed it while you were off drinki...err... "playing". |
Posted: Wed Aug 25, 2010 5:02 pm Post subject: |
Well when he only gets a 3/4 intake setup from me, sometimes things get mixed up in the parts pile.
Bottom line, just call me and I'll let you know what store has your part.  _________________
Posted: Wed Aug 25, 2010 6:48 pm Post subject: |
7th injector changes in years, and the knock sensors are different 350/305
Yeah Holley wants some coin for their new stuff... but it's wicked cool and wicked easy.
Learning curve of ACCURATELY tuning the stock stuff is much much higher.
I got my old motor tuned more in one day with the abilities of the C950... than in YEARS of burning chips. Just because it was at the press of a button. _________________ A redline a day keeps the carbon away! |
Posted: Wed Aug 25, 2010 7:48 pm Post subject: |
| Twilightoptics wrote: | | Yeah Holley wants some coin for their new stuff... but it's wicked cool and wicked easy. |
I don't doubt that, I'm just thinking that said ease comes with a price tag that's over a thousand bucks higher than a comparable MegaSquirt ECM/harness combo, or other aftermarket combo.
In about a month I'm gonna be in the same boat as Greg, the only problem is that with my setup I have no hope of running an older stock ECM, so I can pay for a modern ECM tuning setup and bogus "credits", or buy a new aftermarket setup. Either way it's a big cash outlay.
Now I just need to get my roommate/housing/shop situation ironed out, and I can get back to building.
| Twilightoptics wrote: | | 7th injector changes in years |
I believe the seventh injector remained fairly static throughout the years, Paul.
Somewhere around the same time as the changeover to MAP they changed the small tubes on the runners (later years only have one on the pass. side IIRC). They also changed the IAC port in the TB and upper plenum. Using the wrong runners causes a massive vacuum leak, while using the wrong plenum causes lack of idle control. John's car had both problems, which ironically balanced each other out somewhat.  |
Posted: Thu Aug 26, 2010 4:25 am Post subject: |
Several things change thru the years. But same year 305 vs 350. Its injectors, and also the knock sensor as someone mentioned.
Thru the years...
Fuel rail due to CSI
Runners due to CSI
Base intake due to different heads
Plenium due to map/maf (map has extra vac port)
Throttle body due to different trottle cables and tps
IAC plate (LTI plate will work on TPI body)
dual snorkle.. due to maf
boot from snorkle to TB |
Posted: Thu Aug 26, 2010 5:47 am Post subject: |
They still offer the C950 harness and ecu for about $800.
And those avenger setups he was looking at was with manifold. He'll need an intake with a MS system too. MS is even steeper in learning curve than burning GM chips or Branded aftermarket.
LOL yes I meant 9th cold start injector. Getting too used to dealing with 6 cylinder engines that now have a 7th injector that's plumbed into the exhaust. Heh yes it actually puts diesel into the exhaust. _________________ A redline a day keeps the carbon away! |
Posted: Thu Aug 26, 2010 8:31 am Post subject: |
| Twilightoptics wrote: | | They still offer the C950 harness and ecu for about $800. |
Summit has the Commander ECU/harness combo listed at $1099 plus shipping, and the Avenger combo w/out intake for $1132. MS with harness or HPTuners setup with the stock ECM are both coming out around $500~
| Twilightoptics wrote: | | MS is even steeper in learning curve than burning GM chips or Branded aftermarket. |
That's my only big concern with those setups. I actually tend to drive my crazy projects as dailies.
| Twilightoptics wrote: | | Heh yes it actually puts diesel into the exhaust. |
To cook off the particulate filter or something? |
