Stalls when hot
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Thu Aug 19, 2010 6:02 pm    Post subject: Stalls when hot Reply with quote
I can drive around for 15 miles or so no problem but when the car has to sit in traffic it begins to stall and eventually quits. I have to let it park for a bit then it will be drivable again. It seems kinda rich. I did put a new fuel pump in last yr but I didnt update the fuel regulator. Its a hi flow pump. I can get pressure readings soon to see whats at the rail. It only has 67k on it. Any ideas? Injectors? The MAF sensor?
PostPosted: Thu Aug 19, 2010 7:50 pm    Post subject: Reply with quote
Ignition Control Module.
PostPosted: Sat Aug 21, 2010 6:07 pm    Post subject: Reply with quote
Dirty IAC and TB. Wink
85 T/A WS6
PostPosted: Sun Aug 22, 2010 5:42 pm    Post subject: Reply with quote
I did the ICM today along with a new cap and rotor.
At first it ran better than before but when brought up to temp it began the rough idle and then the death mode. This time I stayed close to home so no big deal, let it cool and limp home.
I was looking at the paper that came with the ICM and it indicated that a bad coil could cause the ICM to go bad by fail due to gimped plugs and wires. I will keep that in the back of my mind.
Not sure how long the ICM will hold up due to these bad conditions, who knows that could be the problem and I just dusted a new part.
It tossed a code 44 at me too, so looks like an O2 sensor.
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
The only thing I know fore sure is it is temp related, it will run like a bat out of hell until it heats up.
MrMike98
PostPosted: Sun Aug 22, 2010 5:59 pm    Post subject: Reply with quote
when the car is cold the engione is in "open" loop mode and the computer uses info on chip to run engine, after ~150 degrees engine goes into "closed" loop mode and now the computer uses all the sensor inputs to control fuel etc. so if u have say a bad o2 , u wont notice it untill u warm up to closed loop mode. sound like a new o2 is in order.
i hope u can understand my idea here.
Mike
PostPosted: Sun Aug 22, 2010 6:43 pm    Post subject: Reply with quote
Are you set up to datalog? If so you can watch the O2 output. In my experience Chevy O2's rarely throw codes. They just crap up.
Cheap as hell to replace, though. Don't buy the Bosch ones everybody sells or you'll be replacing it again withing a thousand miles. Get the NGK/NTK or Delco or something.
Could also be a coil overheating. Have to check for spark when it is actively crapping up.
PostPosted: Sun Aug 22, 2010 7:23 pm    Post subject: Reply with quote
Mike
Mike seems to have a good line of thinking here. Does it progressively get worse as it warms up or is it like a light switch that just pops over and you're running like a dog?
91camaro_rs
PostPosted: Tue Aug 24, 2010 12:52 am    Post subject: Reply with quote
this problem just happened to me, pickup coil and ICM went bad, distributor was a tad bent as well, replaced the entire distributor and havent had a problem since
85 T/A WS6
PostPosted: Sat Aug 28, 2010 8:39 am    Post subject: Reply with quote
Its a fast ramp up to stall, not like a switch though. What O2 sensor would be the 44 code? Would a dealer have a better way to read the code so I dont keep throwing parts at it? I guess a new coil wouldnt hurt and I have not changed the plugs since I had it Embarassed
PostPosted: Sat Aug 28, 2010 8:49 am    Post subject: Reply with quote
An '85 Trans Am only has one oxygen sensor, so that one would probably be the one throwing a code. Wink
Dealers = morons. And they'll want eighty bucks for to tell you the exact same thing you can find out with a paper clip.
Plugs are cheap and easy. You can also inspect the wires while you're at it. Have you ever checked for spark while it was crapping out?
85 T/A WS6
PostPosted: Sat Sep 11, 2010 5:30 pm    Post subject: Reply with quote
Have not checked plugs yet. Where is the sensor, at the cat?
PostPosted: Sat Sep 11, 2010 10:01 pm    Post subject: Reply with quote
Driver's side of the Y-pipe, right below the manifold.
85 T/A WS6
PostPosted: Sun Jan 30, 2011 5:14 pm    Post subject: Reply with quote
Ty.
Its beed 6 months in the garage so I replaced the O2 Sensor today. Code went away so it seems a plug change is next to fine tune it.
Im looking at a 03 50th Anniversay Vette Vert now, so it may be time to sell the bird Confused
PostPosted: Sun Jan 30, 2011 6:57 pm    Post subject: Reply with quote
85 T/A WS6 wrote:
Ty.
NO!!! Shocked
PostPosted: Sun Jan 30, 2011 7:11 pm    Post subject: Reply with quote
85 T/A WS6 wrote:
Ty.
NO!!! Shocked
The birdie is much cooler than any C5.
PostPosted: Sun Jan 30, 2011 8:51 pm    Post subject: Reply with quote
85 T/A WS6 wrote:
Ty.
Its been 6 months in the garage so I replaced the O2 Sensor today. Code went away so it seems a plug change is next to fine tune it.
Im looking at a 03 50th Anniversary Vette Vert now, so it may be time to sell the bird Confused
[joey]Whoa.[/joey]
I can't imagine that bird in anyone else's hands... Or more importantly I can't imagine anyone else appreciating it as much as you.
85 T/A WS6
PostPosted: Fri Feb 04, 2011 4:12 pm    Post subject: Reply with quote
Thanks guys. Its a tough choice. I listed it on Craigs. Had it for 10 yrs and 10k miles
The C5 is nice though Very Happy
http://cid-727261457139d766.photos.live.com/self.aspx/New%20album/2003%2050th%20Anniversary%20Corvette
PostPosted: Fri Feb 04, 2011 6:28 pm    Post subject: Reply with quote
Your call Don. I am sure you will have fun either way.
I will say that within the last year my dad got rid of his bitchin' '55 bel air and got a C5 vert. The corvette is a nice car but he is finally admitting he made a mistake and misses the old Chevy.
85 T/A WS6
PostPosted: Sun Jul 31, 2011 5:33 pm    Post subject: Reply with quote
New hi energy coil, Bosch platniums and 8 mm wires. What a pain! Took both my wife and I to get this done. Ran like a champ then died, it seems its been the fuel pressure regulator all this time, so I just put in a Hypertech adjustable and dialed it up to 48 lbs. Looks like were back in business, thanks guys.
