BigDaddyVu 12sec Club
Posted: Sat Jul 17, 2010 7:48 pm Post subject: heater control valve |
Can any of you guys have a pic of your heater control valve on any v8 between 72 to 84 gm vehicle??? car or truck i can't locate the correct valve for my 84 t/a at any autoparts store. i need one for the 3/4 side. thanks _________________
Posted: Sat Jul 17, 2010 8:27 pm Post subject: |
I know this doesn't help you specifically but why not delete it? _________________
Posted: Sat Jul 17, 2010 9:22 pm Post subject: |
i deleted the valve in '94 tired of hot air blowing on me while driving in the heat and it defeats the purpose of having ac. just don't want a mullet mod anymore. _________________
Posted: Sun Jul 18, 2010 8:19 am Post subject: |
I have one sitting around. Later than what you're looking for since it came from one of my cars, but I forget which one - likely the V6. Operates with vacuum applied to it. They all look the same to me... _________________ 92 Camaro
Posted: Sun Jul 18, 2010 9:41 am Post subject: |
cool thanks _________________
Posted: Sun Jul 18, 2010 9:43 am Post subject: |
| Some of them only had two lines IIRC. |
Posted: Sun Jul 18, 2010 10:01 am Post subject: |
This is for 87 on up gm with bypass
This is the one but only has 5/8 nipples
This one has 3/4 nipples if you have this style on any of your GM i like to see a pic of it in your car/truck.
Posted: Sun Jul 18, 2010 10:09 am Post subject: |
the last pic is for a 82 to 87 El Camino _________________
Posted: Sun Jul 18, 2010 10:16 am Post subject: |
Mine is like the first pic. Never seen the third style before. _________________ 92 Camaro
Posted: Sun Jul 18, 2010 10:40 am Post subject: |
| They make hoses that are 5/8" on one end and 3/4" on the other. |
Posted: Tue Jul 20, 2010 5:11 pm Post subject: |
ok i found one they are only equiped on vechiles with high options which includes ac but not every car came with them. Commonly found in cadilacs and other lux cars. _________________
