Posted: Wed Feb 02, 2005 8:22 pm Post subject: |
$2400 is actually pretty cheap to come up with a rebuilt 305 and installed for you. Figure the rebuilt engine is atleast $850 + gaskets + labor.
Rod's right though, it's not an engine rebuild, yet. Maybe Brandon while chime in, but I think know that rod knock comes and goes that erratically..
I still think it's something ignition related because that's what you change last. |
kidcamaro Member
Joined: 09 Jan 2004 Posts: 325 Location: eugene/springfield
Posted: Fri Feb 04, 2005 4:26 pm Post subject: |
| my friend that i had look at it today said it might be the fuel pump. his friend that was there had a camar o like mine and he said his did the same thing when his fuel pump went out on him. imma get a fuel pressure gauge tomorrow and check it out. |
Posted: Sat Feb 05, 2005 1:19 am Post subject: |
| kidcamaro wrote: | | my friend that i had look at it today said it might be the fuel pump. his friend that was there had a camar o like mine and he said his did the same thing when his fuel pump went out on him. imma get a fuel pressure gauge tomorrow and check it out. |
SET THE TIMING PROPERLY! |
kidcamaro Member
Posted: Sun Feb 06, 2005 10:47 am Post subject: |
| which wire is the ecm one? i asked before and no one answered yet. it doesnt say in the manual. |
Posted: Sun Feb 06, 2005 12:09 pm Post subject: |
| Twilightoptics wrote: | | All you did was the dizzy right? If so, there shouldn't be anything tapping. Look for a tan wire with a brown stripe by your heater box/passenger side firewall. It's a single wire with connector. Unplug that, and set timing. And then see what happens. |
I think this might be the one. |
kidcamaro Member
Posted: Sun Feb 06, 2005 12:18 pm Post subject: |
doh. i didnt even see that and i looked at it a few times. my bad.  |
