		| Author | Message |
		| 86toy Member
 1986  Pontiac  Trans Am
				|  Posted: Sun May 02, 2010 9:05 am    Post subject: 350 upgrade ? |   |
				| Hey guys, im thinking about getting a 350 shortblock for my 86 t/a. i was wondering, how well the 305 heads will work on the 350? motor will be basicaly stock maybe a mild cam. thanks shad.
 86 t/a 305 tpi 700r4 3.73 possi 4 wheel disc
 245/45/17 restoring
		| Back to top |  |
				|  Posted: Sun May 02, 2010 10:46 am    Post subject: |   |
				| Need more information on the motor and specific heads. Deck Height, Bore, Chamber size, piston CC etc. _________________
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Sun May 02, 2010 11:03 am    Post subject: |   |
				| If you have factory dished pistons it would probably be an ok match. Flat tops you'll probably have too much compression without some work to the heads. |  |
		| Back to top |  |
		| IROCDave Member
				|  Posted: Fri May 28, 2010 5:06 pm    Post subject: |   |
				| I would not install 305 heads on any 350. My wifes car has this settup, it makes good tourqe until 3K then falls on it's face. Spend another 500.00 and pick up a decent set of 350 heads. It will be money well spent. |  |
		| Back to top |  |
				|  Posted: Fri May 28, 2010 5:26 pm    Post subject: |   |
				|  	  | IROCDave wrote: |  	  | I would not install 305 heads on any 350. My wifes car has this settup, it makes good tourqe until 3K then falls on it's face. Spend another 500.00 and pick up a decent set of 350 heads. It will be money well spent. |
 Really depends on the heads and cam and heads that WERE on there.
 Seen lots of 70's low compression smog motors wake up with a 305 head.
		| Back to top |  |
		| IROCDave Member
				|  Posted: Fri May 28, 2010 6:01 pm    Post subject: |   |
				| The minor bump in compression is not worth the loss of flow that the tiny 305 valves provide. Spend the dough and at a minimum, use a set of L98 cast iron heads. Keep in mind you can pick up a set of superior alluminum after market heads that flow well for 500.00 or less. See my post regarding trading a used set of TrickFlows for a SR. No need to cheap out on a decent set of heads nowadays. |  |
		| Back to top |  |
