				 Posted: Thu Jan 27, 2005 7:19 pm    Post subject: Got my new G-tech |
				Ran a 14.4 @ 97 mph.
This little marvel of Japanese engineering informs me that I have infact made my car slower than it was a year and a half ago.   |
   1990  Chevrolet  Camaro RS
				 Posted: Thu Jan 27, 2005 7:23 pm    Post subject:  |
				| don't worry, according to g-tech, i'm still in the 14's too.  but I do trap more than 97 :p :p :p |
				 Posted: Thu Jan 27, 2005 8:20 pm    Post subject:  |
				 	  | Dewey316 wrote: | 	 		  | don't worry, according to g-tech, i'm still in the 14's too.  but I do trap more than 97 :p :p :p |
on the bottle?   |
				 Posted: Thu Jan 27, 2005 8:23 pm    Post subject:  |
				with a cold bottle, and on the test run, actualy really eased into it , until the revs were up in 2nd.  And I was only jetting at 100hp.
went 14.1 @ 103 according to mikes tazzo.
what would you have said, if I told you it without the nitrous? |
				| Told ya Rod, don't listen to it. Just make changes to the car and see if your trap speed improves. ET can vary ALOT by traction. |
				 Posted: Thu Jan 27, 2005 8:29 pm    Post subject:  |
				| I'll add that for what it is worth, I have gone 14.6 @ 96 NA on the tazzo.  wif just a widdle tree-o-five. |
				 Posted: Thu Jan 27, 2005 9:51 pm    Post subject:  |
				| As long as I can get some consitancy (sp) then I will be able to use it as a tool to help tune. |
		alloy T56 Elitist
				 Posted: Mon Jan 31, 2005 10:26 pm    Post subject:  |
				| Hey, can someone tell me what fuse th g-tech takes? I was going to loan mine out and realized the tip of the power adapter came unscrewed. I found the tip parts, but no fuse.  And the manual doesn't have a spec for the fuse. |
		vega_guy_76 Member
  Joined: 02 Jan 2005 Posts: 79 Location: St Helens, OR
				 Posted: Sat Feb 05, 2005 2:56 pm    Post subject:  |
				 	  | alloy wrote: | 	 		  | Hey, can someone tell me what fuse th g-tech takes? I was going to loan mine out and realized the tip of the power adapter came unscrewed. I found the tip parts, but no fuse.  And the manual doesn't have a spec for the fuse. |
My G-tech is the original unit and takes a 1amp fuse.
Charlie |
