Posted: Sun Mar 14, 2010 8:54 pm Post subject: Valvetrain action at 14k+ rpm. |
All I can say is wow.
Amazing to see what is going on inside there, while stuff is really spinning.
http://www.youtube.com/watch?v=nsa6kq-qqIE _________________
Posted: Sun Mar 14, 2010 9:29 pm Post subject: |
Those valve springs rotate pretty fast at peak rpm's. |
Posted: Sun Mar 14, 2010 9:33 pm Post subject: |
| aaron_sK wrote: |
That's for sure!! All I could see was the springs rotating, too fast to see any compression. I could see the "shadow" of the cam lobe, it was just a blur...  _________________ 92 Camaro
Posted: Sun Mar 14, 2010 9:42 pm Post subject: |
| It's too bad they didnt have any stop motion going. You should be able to see the springs do all sorts of weird things with that. |
Boostd1 12sec Club
Joined: 28 Oct 2008 Posts: 437 Location: Thornton, Colorado
Posted: Sun Mar 14, 2010 11:12 pm Post subject: |
Imagine the pistons. _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
2008 Saturn Astra XR | Sold
2007 Infiniti G35x | Current DD |
Posted: Tue Mar 16, 2010 7:04 pm Post subject: |
stick your finger in there... I dare you  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Mar 16, 2010 7:10 pm Post subject: |
| DBL_TKE wrote: | stick your finger in there... I dare you  |
You first  |
Posted: Tue Mar 16, 2010 7:12 pm Post subject: |
Sounds like you have the same fascination with moving things I do.. Wow, lookit that fan go.. I wonder if I could touch it..  |
