Horsepower
Goto page Previous  1, 2, 3  Next
Kyleneon
New Member
1999 Chevrolet Camaro
PostPosted: Wed Mar 10, 2010 10:48 am    Post subject: Reply with quote
^ Owned!
99' Neon R/t boosted 300+rwhp
PostPosted: Wed Mar 10, 2010 11:30 am    Post subject: Reply with quote
mines only the TII turbo i wish it was a TIII im debating on a swap, i may pick up a complete engine i've found and rebuild it for more power, i've been on that allpar website just have'nt payed attention to it yet, two weeks off i'll be doing some research i think.
PostPosted: Wed Mar 10, 2010 12:55 pm    Post subject: Reply with quote
No.... You need less boost or more fuel to get you out of the dangerous 14+:1 Ratio.
Think about it: Mopar 2.2L Turbo starting in 1984:
"Chrysler used a Garrett Research T-3 turbocharger, including an integral wastegate, with a maximum boost of 7.2 psi;"
Not 14. And not your 11psi. They cranked the boost without adding fuel. Good thing your motor is tired, all the boost pressure is just passing the rings and not blowing up!
What to know about your motor:
http://www.allpar.com/mopar/22t.html
Later on that page:
The next most common engine after the Turbo I, it added an intercooler, forged crank, and other performance touches, including a heavy duty transmission. An astounding 174 hp came from this reliable engine - not bad considering the original was only 93 hp - and that it came with 200 lb-ft of torque. The intercooler dropped the charge air temperature by up to 120° Farenheit, allowing boost to go from 7.2 psi to 12 psi. Small tubes drilled between the cylinder bores at the top deck were added to cool the engine more effectively, an important modification.
His motor is the Turbo-II, which is factory 12psi. The Turbo-I was 7.2psi.
Regardless, there IS a problem and it needs to be fixed. It's just not due to boost pressure.
Greg, it is a Garrett T3 turbo on a Chrysler Turbo-II motor. Fix your fueling before you do anything else to that motor.
Very Happy
PostPosted: Wed Mar 10, 2010 2:15 pm    Post subject: Reply with quote
I totally missed that. Looked all over on that page too.
My mistake.
It's still not factory 14psi Wink
PostPosted: Wed Mar 10, 2010 2:49 pm    Post subject: Reply with quote
My mistake.
True. And it's still not fueling right as well.
/hijack
PostPosted: Sat Mar 13, 2010 9:52 am    Post subject: Reply with quote
This year I put down 372hp/353ft-lbs N/A and 475hp/450ft-lbs w/N20
I hadn't made any changes N/A. I guess the butt dyno did lie on the juice in that I thought I would be up over 500hp. What it didn't lie about is that 475hp at the wheels feels GOOD!
hehe
Dyno wide-band showed me getting real lean. A bit frustrating because we dialed things in with the brand new wide band in the car. Nothing blewed up and had a good time though.
Boostd1
PostPosted: Sun Mar 14, 2010 11:02 pm    Post subject: Reply with quote
Some good numbers Shultzy! What wideband are you running?
2008 Saturn Astra XR | Sold
PostPosted: Mon Mar 15, 2010 6:52 am    Post subject: Reply with quote
Just put an AEM in. Much easier setup than the Innovate.
My N/A numbers are down ~30hp compared to 2 years ago with the dual 3" exhaust. Still gets the job done though Wink
Boostd1
PostPosted: Wed Mar 17, 2010 10:23 am    Post subject: Reply with quote
x2 on that. UEGO is much more user friendly. Anyway, some good numbers man.
TurdGen1989
PostPosted: Wed Mar 17, 2010 2:57 pm    Post subject: Reply with quote
completely off topic and no help to greg BUT.... thats a sweet sig boostd Laughing
Phil.
GMC High Sierra
Boostd1
PostPosted: Wed Mar 17, 2010 3:45 pm    Post subject: Reply with quote
Haha thanks man. Too bad I got my ass handed to me on that race Sad
PostPosted: Wed Mar 17, 2010 4:06 pm    Post subject: Reply with quote
Against what?
Boostd1
PostPosted: Wed Mar 17, 2010 4:08 pm    Post subject: Reply with quote
11 second 1st Gen Eclipse. Embarassed
PostPosted: Wed Mar 17, 2010 4:13 pm    Post subject: Reply with quote
lol, you can spin the fronts, but the DSM can spin all gfour. Laughing
Boostd1
PostPosted: Wed Mar 17, 2010 4:24 pm    Post subject: Reply with quote
Yeah, pretty well knew I was fvcked when I seen slicks on all 4 wheels Laughing
PostPosted: Wed Mar 17, 2010 9:39 pm    Post subject: Reply with quote
Boo eclipse.
PostPosted: Thu Mar 18, 2010 4:33 am    Post subject: Reply with quote
+1
PostPosted: Thu Mar 18, 2010 6:48 am    Post subject: Reply with quote
Shocked Laughing Laughing Laughing
PostPosted: Thu Mar 18, 2010 1:10 pm    Post subject: Reply with quote
Laughing so hard it hurts Laughing so hard it hurts that is awsome !! Hmmm I wonder if I should show this to Corey. Laughing
PostPosted: Thu Mar 18, 2010 2:44 pm    Post subject: Reply with quote
Yes!!!
Page 2 of 3
