brake booster problem?
86toy
1986 Pontiac Trans Am
PostPosted: Wed Feb 17, 2010 5:27 am    Post subject: brake booster problem? Reply with quote
I am hearing a hissing or swooshing sound when i apply my breaks. is it possibly my break booster? leaking. my break light is on in the dash, plus the break pedal is soft, but when i pump the breaks they work good. but light still stays on. Confused
86 t/a 305 tpi 700r4 3.73 possi 4 wheel disc
245/45/17 restoring
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Feb 17, 2010 7:57 am    Post subject: Reply with quote
Normally, when the booster goes bad, the peddle gets stiff/hard.
But then again, the hissing sound sounds like the booster.
Light on has nothing to do with the booster, thats is normally the mc itself.
I would start at the mc itself.
PostPosted: Wed Feb 17, 2010 7:09 pm    Post subject: Reply with quote
Does it hiss only while the pedal is moving? or does it continue to hiss while you hold the brake?
If its only while its moving I wouldnt worry bout it. If it hisses the whole time your foot is on the brake then you need a booster. The diaphram has cracked and when you flex it, it opens up and sucks air.
PostPosted: Wed Feb 17, 2010 10:43 pm    Post subject: Reply with quote
Hmmm, When I press my brakes there's a hissing sound, and even after replacing my brakes all around they still suck. I'm watching this closely.
86toy
PostPosted: Wed Feb 24, 2010 7:43 pm    Post subject: Reply with quote
It hisses,s all the time until i let off the pedal now, so im possotive its the brake booster is leaking internaly,which sucks Confused
245/45/17 restoring
PostPosted: Thu Feb 25, 2010 11:21 am    Post subject: Reply with quote
likewise. My car hasn't been stopping like it should for quite a while. Haven't noticed a hissing, but the petal is uber-stiff.
