Posted: Sun Dec 27, 2009 9:42 pm Post subject: You bring me beer, you get this free junk |
Mojo say, garage full of useless Chevy junk. Mojo also say you bring a beer or two, you take junk, life improves.
gone-K&N kit for dual-snorkle Camaro. Has both filters and a recharge kit that was used maybe twice. Filters are dirty as heck, but not smashed or anything.
gone-Non-gfx rear bumper off some Berlinetta or something. Blue. Not cracked. Has nifty 'Mean Poeple Suck' bumper sticker. Put it on your Sport Coupe, or just use the sticker to piss off mean people (a good idea overall).
holding for Gabe-Stock T-56 shifter. Because you just spent two grand on your T-56 swap, but you don't want to spend a couple hundred bucks on a Pro5.0.
Still got it!-Oil pump spacer for IROC-style oil cooler. No idea why I didn't throw this away when I pulled it. You can take advantage of my laziness though.
holding for John-ECM from 3.1 car ('91 Camaro IIRC)
holding for Chris-Summit liquid-filled fuel pressure gauge. Carb-style, max pressure is like 16psi. Has NPT thread on it. Was used for maybe two days.
-Shiny chrome dipstick for TH350 trans. Used. Still dips good though.
[-Lokar knockoff dipstick for some trans, I think Ford C6, might be wrong. Never used. Has stainless tube, plastic flexible stick, solid base with o-ring. Kind of a cheapo knockoff.
gone-Taillight lenses for 73-87 Chevy/GMC truck or Bee-Lazer. No cracks.
-Turn signal stalk for Chebbie column. Cruise (with harness). Multi-speed wiper. Paint kinda worn.
-Inspection shield for 700R4 transmission from Camaro, plastic, kinda rough shape.
-Inspection shield for TH350 transmission from 4x4 K5, metal, good shape.
Posted: Mon Dec 28, 2009 12:55 am Post subject: |
I might be interested in that 3.1 ecm. I've got one now 'cause I was toying with the idea of swapping to the '730 and doing some chip burning. I assume it has the stock chip in it? Harness? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Dec 28, 2009 6:51 am Post subject: |
| Stock chip, yes. I forget what happened to the harness. I don't think I ever got it. |
Posted: Mon Dec 28, 2009 8:21 am Post subject: |
Aaron, want to hold onto the T56 shifter for me for the next time we meet up? Maybe I'll road trip up to Tacompton with the 'maro and visit. If not, bring it to a gathering.
I cannot repay with alcoholic beverages, will Mojo be angry? Acceptable substitutes? _________________ 84 Camaro Z28 - LS1/T56
Posted: Mon Dec 28, 2009 5:16 pm Post subject: |
Gabe, I've had that thing since I did my T56 swap in 2007, I can hang onto it a few more months.  |
Posted: Tue Dec 29, 2009 8:11 am Post subject: |
Cool, figured you'd hook me up. I'll PM you when my Camaro is roadworthy (tires and exhaust hanger) and see if we can meet up sometime. I'd rather not wait a few months if the alternative is a trip with the fun car.  _________________ 84 Camaro Z28 - LS1/T56
kurfbird Member
Posted: Tue Dec 29, 2009 6:50 pm Post subject: I can probably pick up everything else |
I can probably pick up everything else on saturday _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Tue Dec 29, 2009 6:58 pm Post subject: Re: I can probably pick up everything else |
| kurfbird wrote: | | I can probably pick up everything else on saturday |
kurfbird Member
Posted: Fri Jan 01, 2010 5:12 am Post subject: Aaron |
Pm me your info and I will come by saturday morning to get the stuff _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Fri Jan 01, 2010 10:07 am Post subject: |
| Bruce, you got PM dude. |
Posted: Fri Jan 01, 2010 7:14 pm Post subject: |
I'm kind of interested in the K&N filter and kit. I won't be driving up North anytime soon though. Maybe you can hang on to it until the next gathering? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Fri Jan 01, 2010 7:21 pm Post subject: |
| DBL_TKE wrote: | | I'm kind of interested in the K&N filter and kit. I won't be driving up North anytime soon though. Maybe you can hang on to it until the next gathering? |
Bruce had first dibs on it, unless he decides he doesn't want it. |
Posted: Fri Jan 01, 2010 7:30 pm Post subject: |
Yeah I just noticed that after I replied, no big deal. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Jan 02, 2010 2:18 am Post subject: |
I'm intrested in the fuel pressure gauge.
no idea when I could head up to Tacoma and pick it up though.
if someone local wants it, they can have first dibs. _________________
kurfbird Member
Posted: Sat Jan 02, 2010 2:22 am Post subject: taili lights |
Interested in also _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sat Jan 02, 2010 9:18 am Post subject: |
Chris, you coming to dyno? I'll hold it till then.
Bruce, you can have 'em when you swing by today. |
kurfbird Member
Posted: Sat Jan 02, 2010 7:23 pm Post subject: Thanks for everything |
Thanks for everything _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sat Jan 02, 2010 7:29 pm Post subject: |
Found that other taillight and the oil cooler about an hour after you left. They're yours next time you're up here if you want them, Bruce. |
kurfbird Member
Posted: Sat Jan 02, 2010 7:29 pm Post subject: LOL |
Okay sounds good. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sun Jan 03, 2010 10:33 am Post subject: |
| aaron_sK wrote: | Chris, you coming to dyno? I'll hold it till then.
I will most definitely be at dyno. _________________
