And so my problems continue
Should i shoot my car with a rpg?
yes
25%
 25%  [ 2 ]
no
37%
 37%  [ 3 ]
shiboopi
37%
 37%  [ 3 ]
Total Votes : 8
TurdGen1989
PostPosted: Tue Dec 01, 2009 4:26 pm    Post subject: And so my problems continue Reply with quote
OK, so after i replaced my plug wires and cap the car was running good...
but now a week later the hesitating has came back, not only that but it wont even idle in the morning i have to essentially serve as the choke because the rpms wont go above like 300 and it will die.
On the freeway i will be driving and and the rpms will randomly drop and sometimes it feels like i'm just holding the brake but really i'm holding the gas firmly. This is really starting to piss me off and i have no clue as to what to do. any ideas?
Thanks guys
phil.
Phil.
GMC High Sierra
PostPosted: Tue Dec 01, 2009 5:31 pm    Post subject: Reply with quote
sounds maybe like a fuel delivery prob to me but the other guys will know better
PostPosted: Tue Dec 01, 2009 6:20 pm    Post subject: Reply with quote
Is wires/cap all that you have done?
What are the plugs looking like?
TurdGen1989
PostPosted: Tue Dec 01, 2009 6:34 pm    Post subject: Reply with quote
plugs are less than 2 weeks old
Phil.
GMC High Sierra
PostPosted: Tue Dec 01, 2009 6:47 pm    Post subject: Reply with quote
Did you replace the rotor as well?
Could be a number of things yet.
TurdGen1989
PostPosted: Tue Dec 01, 2009 6:51 pm    Post subject: Reply with quote
yes everything to do with ignition I've done cap,rotor,plugs,wires,coil
Phil.
GMC High Sierra
PostPosted: Tue Dec 01, 2009 6:55 pm    Post subject: Reply with quote
I'd go to fuel filter next.
kurfbird
PostPosted: Tue Dec 01, 2009 7:05 pm    Post subject: Igntion module Reply with quote
Have you replaced the pick up coil??
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Tue Dec 01, 2009 7:16 pm    Post subject: Reply with quote
sorry nothing constructive to add, but I voted RPG cause I would like to see something blown up in just such a fashion. Actually my old boss comes to mind.
I'm back to the sidelines now.
Killing mailboxes since 2009
TurdGen1989
PostPosted: Tue Dec 01, 2009 7:20 pm    Post subject: Reply with quote
^ haha...
someone voted shiboopi lolz!
anyway... fuel filter is flowing fine not clogged or anything...
anyone think it could be my TPS?
Phil.
GMC High Sierra
PostPosted: Tue Dec 01, 2009 7:24 pm    Post subject: Reply with quote
You've had a pressure gauge on while driving when it hesitates to verify you don't have any fuel cloggage? Arrow
PostPosted: Tue Dec 01, 2009 7:26 pm    Post subject: Reply with quote
I didn't get all of my wires connected securely to the plugs and developed a random miss. Felt secure when I installed them, but after a bit of driving and the occasional miss, I got home and looked under the hood to see #7 boot almost free of the plug. Might be worth re-checking your connections.
PostPosted: Tue Dec 01, 2009 8:24 pm    Post subject: Reply with quote
+1 on this.
Throw a vacuum gauge on it too. Never hurts.
TurdGen1989
PostPosted: Tue Dec 01, 2009 8:33 pm    Post subject: Reply with quote
alrighty ill do that tomorrow after work
Phil.
GMC High Sierra
91camaro_rs
PostPosted: Tue Dec 01, 2009 10:26 pm    Post subject: Reply with quote
i had a similar problem and it was my fuel, first the filter, and it keep givin me problems....had the fuel injectors tested and 4 of em were bad, and on one the pintle was stuck open
PostPosted: Tue Dec 01, 2009 10:28 pm    Post subject: Reply with quote
He's only got two of those anyway. Razz
PostPosted: Wed Dec 02, 2009 7:43 am    Post subject: Reply with quote
If spark is all you tackled so far, you have along way to go before you need to blow it up.
Agree with others, check fuel next. Have you, yourself, changed the fuel filter? Just cause it flows, doesnt mean its enough. Change it, its 10 bux and less then 1hrs work. Next I would put a fuel pressure gauge on it. I know that is a MAJOR pita on a tbi, but that is next. Also visually look at the spray of the injectors. I know of a tbi truck that ran and was sluggish, but one injector was obvisully not spraying as much as the other.
As mentioned in your previous post. Did you check timing, with the est wire disconnected?
After that, we go onto sensors.
91camaro_rs
PostPosted: Wed Dec 02, 2009 10:14 am    Post subject: Reply with quote
haha i have made that mistake too, car was running wierd, re-timed it with the est disconnected, and then i had no more problems
Outlaw28
PostPosted: Wed Dec 02, 2009 1:52 pm    Post subject: Reply with quote
haha im thinking the same thing...but on a constructive note...did you say its tpi or carb??? i agree with the other guys get a fuel pressure gauge on there...maybe the pump is going out...or it could be something to do with the ecm telling it to cut fuel...who knows to many things it could be at this point
