Posted: Thu Nov 12, 2009 8:24 pm Post subject: Metal That Sounds Like Other Metal |
http://www.youtube.com/watch?v=adukrwHY09s&feature=related
I thought this would spark a little bit of interesting conversation. The link is only to volume 1 but it's pretty amazing how many bands copy each other. There were 7 other bands that used the main riff for 2 Minutes to Midnight. I've listened all the way up to Volume 16 or so. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Nov 12, 2009 8:54 pm Post subject: |
It's not confined to just metal either. In the 80's Huey Lewis sued Ray Parker Jr for using the melody of "I Want a New Drug" for "Ghostbusters" If you listen to the two songs, their beats are almost identical. _________________ 92 Camaro
Posted: Thu Nov 12, 2009 9:20 pm Post subject: |
| Al Hasse wrote: | | It's not confined to just metal either. In the 80's Huey Lewis sued Ray Parker Jr for using the melody of "I Want a New Drug" for "Ghostbusters" If you listen to the two songs, their beats are almost identical. |
Yeah, I've heard the two songs, They really are almost identical. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
