Used 700R4 - make offer
PostPosted: Thu Oct 22, 2009 9:01 pm    Post subject: Used 700R4 - make offer Reply with quote
Just pulled from my '88 305 'bird.
150K miles total, was pulled at 120K to change a planitary gear and sun shell that had cracked. Other than that, it was left alone.
This trans drove in every gear when I pulled it into the garage for the 5-speed swap, Drove it everyday, but had 2 issues; It leaked, and it wouldn't let you do any engine braking, it would slip out of gear if you took it from overdrive to D, 2, or 1. A search tells me that an overrun clutch is fried, or the forward sprag is broken, which both don't require a bottom up rebuild, but with the miles on it, I would recommend a full rebuild anyway, but thats up to the buyer. It does have some kind of shift kit installed brand unknown, but a WOT 1-2 shift would bark the tires.
Also have a flex plate, torque converter and a bunch of other misc. stuff that came out with the 5 speed conversion, feel free to ask.
Trying to recoupe after buying my new trans.
-Derek
PostPosted: Thu Nov 05, 2009 4:01 pm    Post subject: Reply with quote
--Bump
C'mon nobody needs an auto?? lol
I also have a tested good starter for a third gen V8/auto.
$20
