Posted: Mon Nov 08, 2004 1:51 pm Post subject: |
Breath Deep.
Then give 'em hell! |
Midnight Sun Member
Posted: Mon Nov 08, 2004 3:25 pm Post subject: |
Meh.. I very very rarily go to TGO anymore. I will shoot the shizzle at 3GO and NE3G just because I am generally not concerned about pissing anyone off there.(Sorry Kage )
But you guy's I hold highly and between all of you, there is enough technical knowledge to help me with any problem
So :middlefinger: to all those TGO guys, and congrats on posting a good rebuttle to those... asshats. _________________
Raiden Member
Posted: Mon Nov 08, 2004 5:31 pm Post subject: |
I agree there are a LOT of assholes on TGO. However, If you post such a defensive responce, they will all jump on the band wagon and flame you. Personally, I give thanks to the positive input's and ignore the negatrons by either two things. One, say nothing towards them OR tell the postive inputs Thanks for the positive feedback and hte help! Usually, that keeps teh negatron's quiet. If you retaliate, you risk getting flamed by everyone, not just the arseholes  |
Wolffy Member
Posted: Mon Nov 08, 2004 5:40 pm Post subject: |
i stopped cruising TGO like 2-3 years ago, got tired of all the know it all assholes, that jump down your throat the first 3 seconds u are there for any reason.
they all say do a search, well after doing a search & reading thru worthless banter for days on end trying to find a small piece of info, i usually ask & it seems like everytime quite a few of them would be ready to pounce with their standard response of do a search you idiot
so i said so long losers
good going on the backup there dewey !!! |
Posted: Mon Nov 08, 2004 8:59 pm Post subject: |
http://www.chevelles.com/forum/ultimatebb.php/topic/4/22980.html
Look how much better that post is going on Team Chevelle instead of TGO. Much better. Actual useful advice, and from people who actually know what theyre doing! No flaming, just check this or that.
I still think if you want to build a motor get advice on TC. If you want to learn to burn chips go to TGO, or Chevytalk. TC isnt that big on the tech thing, though there are people there who know. But theyre huge into making power, and gettin things to hold together. |
Posted: Mon Nov 08, 2004 10:56 pm Post subject: |
TGO is an excellent site for tech info. Other than that, you gotta take it with a grain of salt.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Mangus Member
Joined: 10 Jan 2004 Posts: 254 Location: @computer in garage (Bothell)
1989 Pontiac Trans Am
Posted: Tue Nov 09, 2004 2:41 pm Post subject: |
*asbestos suit enabled*
I gotta step in here and say that what they're posting isn't unreasonable. There are quite a number of people running the comps without issue. It makes more sense to rule out error on the installer/users part before blaming the company.
Would you immediately look for a Zebra when you see hoof prints? Or would you rule out a horse first?
If, after ruling that out, the problem appears to be with Comp (with reasonable evidence), then fire away at 'em, man! In fact, in that situation, I'm relatively certain that Comp would, uh, Comp(ensate) you.
Your rant a few posts down in the thread, to someone like me who isn't aware of the "history" behind the flames or your feelings, looks quite unjustified.
Its the Internet, man. I defy you to find message boards anywhere without its share of healthy argument, opinion, and discussion.
That said, the folks here (and in my little DIY-PROM world at TGO) are great. |
Mangus Member
Posted: Tue Nov 09, 2004 2:50 pm Post subject: |
| chevymad wrote: | http://www.chevelles.com/forum/ultimatebb.php/topic/4/22980.html
Look at the first reply. Compare it to the first reply at TGO. Also, note the differences in attitude in the original post.
And we shouldn't ignore the difference in forums between the two boards. One was posted in aftermarket product reviews, the other in a bona fide tech section.
Seems logical that the second (chevelle) posting would fair better.
BTW - Twilight - if you get full rollers, let me know how you like them. |
Posted: Tue Nov 09, 2004 5:09 pm Post subject: |
| Mangus wrote: |
Yeah, the Tech / General Engine forum probably would have been a better place to post assuming that you wanted a responce. Since you posted in the Aftermarket Product Review forum you probably didn't expect a responce. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Tue Nov 09, 2004 6:12 pm Post subject: |
Reguardless, I don't know how much you guys tend to surf TGO, but I had seen it day in day out where someone posts and it's either USE THE SEARCH!!!! or It's alienating the person. My rant was just, in the fact that I posted my findings and didn't specifically state that it was comps fault 100%. The idea of the post was to spark others whom may have seen or had the same problems.
And, typically, each time I post on there, I get flamed.... and I was tired of it. Period.
Edit: TC post " Talking to a good friend of mine, it's possible I might be shooting oil OVER the rocker... but then again, these rockers have 5000 miles on them, and it's not good. Doubt comp will even discount a new set or set of full rollers."
TGO post " These have 5000miles on them. Not good. Either bad parts, or I'm shooting oil OVER a select few of them.... Doubt comp will do anything about it either."
Tell me how that is trivaly different? |
Glenn91L98GTA Member
Joined: 21 Oct 2004 Posts: 25 Location: Kamloops, BC Canada
Posted: Wed Nov 10, 2004 7:12 pm Post subject: |
I have never seen that on an "unabused" engine before. I say that, because how it "died" would not be abuse in my opinion. And "pivot ball" technology is usually pretty foolproof (excluding under/over tightening the lash).
The one thing I have really noticed lately, is a LOT of people having problems with Comp Cams parts. And, yes, it does seem a lot of people on TGO, seem to want to blame it on "operator error", instead of Comp Cams.
There is a post somewhere where a guy had a solid roller cam from Comp Cams and had his lobes wiped after a couple thousand miles. Every body jumped on him saying he had to so something wrong - but as the guy said "What can I do wrong? There IS NOT BREAK IN on a solid roller cam (in fact you SHOULDN'T use moly lube as it may clog the oil passages). The rollers, push rods and springs were all Comp Cams and the required specs. So how could it be operator error? (But they all defended Comp Cams and blamed him).
The only mistake the guy made (and he admits it), is that he DIDN'T buy a "billet" cam, just cast and that he regrets. Funny thing, my buddy just went to buy a solid roller cam from Comp Cams, and guess what they only sell now? You guess, billet only - no more cast solid cams.
The problem is, EVEN if Comp Cams cover their parts, it does nothing for the other parts that got destroyed as well as the time/labor.
BTW, the cam I plan to swap to this winter is Crane. |
Posted: Wed Nov 10, 2004 7:17 pm Post subject: |
Almost forgot, I've never seen anyone discuss this before, but most guys with lift in the area you are using tend to use full roller rockers. I seldom see people with that amount of lift use "pivot ball" type rockers.
I'm just wondering if there may be a limit to the amount of lift "pivot ball" type rockers can tolerate. That amount of lift would generate a fair amount of heat with a "pivot ball" type rocker. I realize that lift is with 1.6 rockers, but it still is a fair amount just from the cam.
Just throwing out a thought to consider. (i.e. Pivot ball okay for low/mild lift, rr for high lift). |
Demon 12sec Club
Posted: Wed Nov 10, 2004 9:56 pm Post subject: |
I'm just comfortable in the knowledge that we have enough people here and on TC to the point where I don't have to go to TGO if I have a problem...
numerous people here and on TC have been a great amount of help and they're not near the severity of nazism that TGO has become.
ede in particular... however, since he kisses Dirk's ass and donates quite a bit (and is Dirk's good friend to boot), he has a fairly large amount of room to be a dick on that site.
using the search function is pretty worthless on that site unless you know a string of words in particular, because 90% of the shizzle on that site is just look for it in search anyway and you don't find anything (and a lot of what you do find has either been proven wrong in the long run or has been corrected by a company at some point and isn't the problem you're looking to correct) _________________
Soon to be less than stock |
